adithorp
posted on 29/11/07 at 05:29 PM |
Hypothetical SVA exhaust question?
If a car passes on emissions but fails on noise, do the emissions get tested again at re-test?
adrian
speedyxjs
posted on 29/11/07 at 05:31 PM |
I think the whole test is redone
mookaloid
posted on 29/11/07 at 05:32 PM |
That's a really good question - I would guess not but I don't really know.
mark
Robert Ryan
posted on 29/11/07 at 05:37 PM |
( NO )
AS LONG AS YOU USE THE SAME EXHAUST, THEY WOULD ONLY TEST THE THINGS YOU FAILED ON.
snoopy
posted on 29/11/07 at 05:42 PM |
can also confirm no you would only be tested on the items failed not passed
Guinness
posted on 29/11/07 at 08:01 PM |
Yup, the first test takes half a day, the re-test just covers the fail points, so could be as short as five minutes.
HTH
Mike
smart51
posted on 29/11/07 at 08:21 PM |
My SVA retest was very quick. Emissions, rear reflector edges and 1 or 2 nylocs. They only check the fails.
I would guess that if you change the silencer but keep the cat etc. then they would only check the noise. Surely, though, if you passed emissions
once, then you'd pass again?
adithorp
posted on 29/11/07 at 09:59 PM |
Not if I took the cat' out and replaced it with another silencer that looked the same!
Seeing as its inside the sill it'd be hard to know I'd done it.
The thing is I have easy access to emissions testing to set that up but might be marginal on the noise. I'd have a bolt in cat for mot test
later.
adrian
watsonpj
posted on 29/11/07 at 11:32 PM |
What take the cat out - no surely thats not allowed ![](/images//smilies/bigsmile.gif)
and you shouldn't need it for MOT either mine fell out right after the test and hasn't been needed since. (as long as its a Q plate )
Visible smoke only
THE BEAR
posted on 3/12/07 at 08:59 AM |
as much as i dont wont to tell you all this but i have been to me mot station and the mot book is saying on a q reg the emissions are done on the age
of the engine ![](/images//smilies/sad.gif)
DarrenW
posted on 3/12/07 at 09:46 AM |
In my experiance the SVA man will only test the items that failed, however im sure they reserve the right to check other bits again if they want to.
