Author: Subject: Hispec Brakes - Filing Pads
edspurrier
posted on 1/12/07 at 11:55 AM Reply With Quote
Just got a Hispec 4 post kit for my Avon - from Tiger - it's the M16 replacement kit. Instructions say you have to take 2mm off each Greenstuff pad.
I'm not keen on that idea. Has anybody elese done the same, or should I try to find some pads that fit? Otherwise what's the best way to do it?
posted on 1/12/07 at 11:59 AM Reply With Quote
A file would be the best way to remove 2mm rather then resorting to a grinder.
Werner Van Loock
posted on 1/12/07 at 12:27 PM Reply With Quote
to keep it flat i would use the machine below, don't know how it's called in english, but it's a flat surface that moves. Most of them can be mounted upside down to the workbench. This is a dewalt but the local shop should have some cheaper ones too.
[Edited on 1/12/07 by Werner Van Loock]
http://www.clubstylus.be
iiyama
posted on 1/12/07 at 12:42 PM Reply With Quote
thats a belt sander
If its broke, fix it. If it aint broke, take it apart and find out how it works!
joetait
posted on 1/12/07 at 12:57 PM Reply With Quote
wrong pads
Sounds like they are supplying the wrong calipers for the disc width. Hispec do different width calipers so you should never have to shave the pad. Sounds like Tiger only stock the narrow type - I'd call Hispec to discuss what you have been sold.....
edspurrier
posted on 1/12/07 at 04:41 PM Reply With Quote
False alarm - Tiger said take 2mm off the pads, but meant the lugs at the side. Done. Thanks anyway!
