greggors84
posted on 2/12/07 at 08:11 PM |
HD Film streaming
Ive downloaded a few HD films onto my laptop, but they are very jittery when they play.
I have been looking at getting a remote media player so I can play music and videos in my living room on my big tv and stereo. A few of these play HD
content and use a HDMI connection. I take it wont matter the spec of my laptop as the remote media player is just reading the files off my laptop not
actually using it play them.
I have a G band wireless router and wireless USB dongles (only hooked up to USB 1.1 ports) what sort of connections speeds will i need to stream HD
media succesfully?
Chris
Atomfun
posted on 2/12/07 at 08:17 PM |
I've got stacks of films on my main computer.
I tried to stream them over my wireless network to my laptop in the bedroom - result was crap!
Just purchased some AV Homeplugs - upto 200Mbps - result brilliant
John Cooper
'Ariel makes your whites browner'
greggors84
posted on 2/12/07 at 08:32 PM |
After some quick calcs...
If a 2 hour WMV-HD movie is 8gb
That is 1.1 mb/s
My connection is running at 54mbps (or so the little network icon says in the taskbar) this equates to 6.75mb/s
So in theory I should be ok. If not I can always get some home plugs.
Or is it not as simple as this?
[Edited on 2/12/2007 by greggors84]
SeaBass
posted on 2/12/07 at 08:40 PM |
Not as simple as that calculation. I too have struggled to stream HD over 54g - it uses a lot of the bandwidth for security and packet integrity. I
noticed some of the new Wireless routers are now mentioning HD streaming if you use kit from one manufacturer...
greggors84
posted on 2/12/07 at 08:48 PM |
I take it that was streaming HD from one computer to another instead of from the internet SeaBass?
Chris
The Magnificent 7!
posted on 2/12/07 at 09:12 PM |
I saw something from DivX that looks good
for this kind of thing. It does XviD as well so it should cover most of the internet based stuff. I think it was about £130 in the email so if you
watch a lot of internet stuff it's reasonable I think. Here on the DivX site.
[Edited on 2/12/07 by Peteff]
onzarob
posted on 2/12/07 at 09:38 PM |
I stream Divx HD videos across G with no real issues, but still occasional pauses.
The problem is that there is no QOS on 54 g so you will get pauses etc, for streaming media you need wires. Atomfun solution is best if you
don't want to get a drill out ![](/images//smilies/bigsmile.gif)
posted on 2/12/07 at 10:07 PM |
That is 1.1 mb/s
An 802.11G connection is rated at 54 megabits/s, or a theoretical maximum of 6.75 megabytes/s. In practice, TCP/IP overhead, 802.11B protection, bad
packets, encryption etc. drops that by well over 50%, and depending on other traffic etc. the available bandwidth is rarely stable.
cloudy
posted on 2/12/07 at 10:48 PM |
your bottleneck could be the USB1.1 - around 1.5MB/sec at best...
also any PC still running with USB1.1 I would have serious doubts is able to play back HD?
James
greggors84
posted on 6/12/07 at 06:58 PM |
James,
Its my laptop running 2.4ghz P4, with 739mb of Ram. Its about 5 years old which I guess is why it only has usb1.1
The video card is only 16mb which is why I cant play HD videos directly from my laptop, but if the media streamer just reads the files off the
harddrive then it shouldnt matter the spec of the laptop.
Looks like I will have to get some homeplugs or use a cable for HD streaming then.
Chris
The Magnificent 7!
cloudy
posted on 6/12/07 at 07:00 PM |
ah OK, yes - or use a PCMCIA wireless card? Will have a far higher throughput compared to usb1.1
James
[Edited on 6/12/07 by cloudy]
greggors84
posted on 6/12/07 at 07:32 PM |
Had this problem before when I wanted to buy a external HD, no PCMCIA slot! Strange for a laptop i know.
Ended up getting a firewire one, shame it seems there are no firewire WiFi devices.
[Edited on 6/12/2007 by greggors84]
Chris
The Magnificent 7!
posted on 6/12/07 at 08:03 PM |
You might find GeeBoX interesting it is a bootable Linux cd that turns x86 or Power PC Mac computer into a media player and streaming media
server.
Boots off CD without using the hard disc, I tried it as a media player and found it quite good if a little raw.
http://geexbox.org/en/index.html
[Edited on 6/12/07 by britishtrident]
