Aico
posted on 7/12/07 at 02:02 PM |
BEC engine
Looking for a used kitcar with a bike engine. There are basicly 3 choises within my budget. Fireblade, R1 and the Blackbird. Not looking at prices etc
what is the difference between these engines? Is there a big difference in power and torque? How are the gearboxratio's?
worX
posted on 7/12/07 at 02:08 PM |
Hi Aico,
Fireblade is a well known engine and can be picked up quite cheaply nowadays, but the cheapness does not reflect on the quality of the engine and ease
of install!
The R1 has more power and similarly can be picked up cheap, although not as cheap as the Blade and has more power than the Blade also, but slightly
trickier cooling installation.
The Blackbird is a bit of a "black sheep" only because it has oil surge foibles, and many people suggest that if taken anywhere near a
track you should fit a dry sump (which would make it an expensive package altogether!), although I have no experience of this myself.
I am biased because I have a Blade, and also know that they are a strong engine, with a (relatively) good gearbox, although with the mileage that all
the engine's you are looking for, all with have a few "issues" that need to be checked.
Toady1
posted on 7/12/07 at 02:18 PM |
fit a 954cc blade an itll be as powerfull as an R1! ![](/images//smilies/wink.gif)
mackei23b
posted on 7/12/07 at 02:24 PM |
Lots of ZX9Rs out there as well,
but Fireblade and R1s seem to be the most popular.
Dangle_kt
posted on 7/12/07 at 02:25 PM |
blade could range from a 1994 carbed model to a 2007 cbr1000rr engine - so depending on what your after, ask what it is.
Even carbed Blade engine is well proven and is plenty fast.
r1 has a higher output than older blade engines, but similar to more modern ones - heard of some gearbox issues, but this might be down to oporator
error as apposed to weak gear box.
Blackbird is not 1000cc, it is a bigger engine and is more of a hyper /sports tourer, the bigger engine will make for more civilised midrange grunt -
but if I was buying one 2nd hand I'd like to see proof that the dry sump kit was fitted before the car turned a wheel - 2nd hand cars are a
gamble at the best of times without introducing more concerns to the mix.
Depending on what you want out of the car and what it is for will effect your choice.
If it is for more road use I would be tempted by a blackbird engined BEC.
If for trackday then blade and r1 are both very quick cars.
I have a blade engine for my BEC (still being built) and am happy with my choice. To me a blade engine will be plenty fast enough and if it all goes
wrong then replacement engines are pretty cheap (£300ish) as apposed to serious money the other two engines command. Plus I've read of
fireblades doing 100k miles with no problems.
Aico
posted on 7/12/07 at 02:35 PM |
Looking at my budget the kitcars for sale usually have the older carbed engines. How is the Blackbird against the R1?
worX
posted on 7/12/07 at 02:43 PM |
If my choice were either Blackbird or R1, then I would go for the R1 everyday...
falcor
posted on 7/12/07 at 03:12 PM |
Is there anyone using a Daytona 955i engine in a BEC ?
Pros and cons vs the R1 ?
twybrow
posted on 7/12/07 at 03:30 PM |
I am installing a Dayona (T595) in a Stuart Taylor chassis. It sounds awesome, but it will be a good few more months until I know how it drives. IT
has been an easy engine to sort wiring for, the only issue I have found so far is that it doesn't sit quite as centrally in the chassis as some
of the others, but not a big issue - plus there are no off the shelf parts for the install, but again, not a huge issue.
falcor
posted on 7/12/07 at 03:42 PM |
Cool, do you have any pictures of your install?
twybrow
posted on 7/12/07 at 04:06 PM |
Some in my archive - others available on request!
posted on 7/12/07 at 10:49 PM |
Personally - one of if not THE best engine for a 7 type Kit is the ZX-12R. Tracked and driven hard (and soft) on the road there is little to touch the
power and torque of this engine ('busa allowed) without any real problems. Our's has had frequent trackdays and regular hard road driving
with not one beat missed.
Ignore it at your regret....
Aico
posted on 8/12/07 at 09:49 AM |
Do you need a drysump with that engine for trackuse with semi-slicks? Also how easy or difficult is it to fit in a seven which already has a bike
engine in it? A Fireblade for instance.
[Edited on 8/12/07 by Aico]
NS Dev
posted on 9/12/07 at 11:59 AM |
I'm a car engine man I'm afraid, don't really do the bike engine thing BUT........
Hellfire is right, the ZX12r does make sense, you really do want as many cc as possible, and the busa is mega money for what it acheives.
That said I was disappointed with the performance of a Busa westfield recently as compared to my Vauxhall XE locost, I'm certainly glad I went
with the car engine as it is certainly faster.
Aico
posted on 9/12/07 at 12:11 PM |
What spec is your car engine?
ChrisGamlin
posted on 9/12/07 at 01:42 PM |
I upgraded from a carbed blade to an injected R1 and can say that its not particularly cheap or simple to convert from one bike engine to another.
They generally have different engine mounts, different exhaust, different electrics etc etc. Overall I'd say you'd most likely add
£1k-£1500 on top to convert, including selling the outgoing engine and associated parts.
If you think you might want to do that, it would be far easier and cheaper to raise your budget for the car and buy one ready installed.
NS Dev
posted on 10/12/07 at 01:08 PM |
have u2u you as I don't want to divert the thread!
