Author: Subject: calculating battery requirements
natehall
posted on 31/12/07 at 01:15 AM Reply With Quote
Guys,
I have a pinto engine, which i want to use the smallest possible batter mounted inside the car, what i need to know is how many cranking amps do i need what battery should i get?
the car wont have any unneccessary electronics - just fuel injection and the electrics to get an mot
any help is very appreciated
Kind Regards
Nathan
If it aint broke, uprate it
if it is broke, uprate it
http://www.modders-uk.co.uk
Mr Whippy
posted on 31/12/07 at 01:50 AM Reply With Quote
depends on what cc it is and if it's standard or high compression, you don't say.
zilspeed
posted on 31/12/07 at 07:54 AM Reply With Quote
A mini battery will start a V12 jag engine, if the jag engine is well maintained and the ignition system is spot on. A well maintained Pinto doesn't present a problem.
I always fit a mini battery unless there is a clear and distinct need to fit something else.
As stated above, do you have a mega CR ?
RazMan
posted on 31/12/07 at 09:24 AM Reply With Quote
The smallest batteries are probably the gel type - which are tiny. My Odyssey battery is not the smallest in the range by any means (I can still hold it in one hand though) but it will easily crank a Chevvy V8 with its 680 Amps! A gel type motorcycle battery of around 400 Amps should whizz a stock Pinto around nicely.
p.s. You can reduce your power requirements considerably by fitting LED lights [hint hint]
Raz
Mr Whippy
posted on 31/12/07 at 12:21 PM Reply With Quote
your quite right off course, but when the engine is not so happy to start on the first turn or the weathers gone cold, that's when your problems start.
Mr Whippy
posted on 31/12/07 at 12:23 PM Reply With Quote
shameless bit of advertising there
natehall
posted on 31/12/07 at 10:39 PM Reply With Quote
cc is 2090 running high compression around 10-11:1 iirc
this odysey battery - do you have alink as to where i can find one?
RazMan
posted on 1/1/08 at 01:23 AM Reply With Quote
Linky
Raz
