New Topic New Reply
Author: Subject: Sierra Front Hubs
Gareth
posted on 13/10/03 at 03:56 PM Reply With Quote
Sierra Front Hubs
Can the Cortina front hubs be used instead of the Sierra ones, as in my opinion the Cortina ones look a lot better and I happen to have a pair in the shed?
ned
posted on 13/10/03 at 04:05 PM Reply With Quote
they'll accept the same balljoints, its just whether the dimensions from the hub/spindle to the balljoint holes are the same. come to think of it, the top will be adjustable from the screw in/out transit joint, the only other difference might be to track/wheel offset.
What have i forgotten/missed?
Ned.
beware, I've got yellow skin
theconrodkid
posted on 13/10/03 at 04:24 PM Reply With Quote
probly best to use seirra ones,sell the cortina ones and get yr chassis money back
who cares who wins
pass the pork pies
Ben_Copeland
posted on 13/10/03 at 06:35 PM Reply With Quote
The balljoints i got (ones recommended in the 1st book) DONT fit the Sierra Front Hubs (bottom joint) and the Track Rod End Balljoint is different too.....
Had to drill the bottom balljoint taper bigger, and the track rod end, is too small for the hole in the sierra hub.
Well, thats what I have found anyway !
So that leads me to think that the balljoint supplied for the Sierra Hubs.... wont fit the Cortina Ones !
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 13/10/03 at 06:41 PM Reply With Quote
i think mk sells hubs that are already drilled up to the correct taper and size, and probably then uses normal cortina BJs. My rack fit fine, but then of course it would cos its a sierra rack! never heard about drilling the track rod hole, so maybe people just use the sierra ends.
anyone know the correct taper for the cortina BJ? some good money in that i reckon...
[Edited on 13/10/03 by JoelP]
Ben_Copeland
posted on 13/10/03 at 06:56 PM Reply With Quote
The track rod end hole is too big on the sierra hub for escort track ends..... Hence why you have to use larger sierra ones!
Correct Taper; easy just measure the ball joint that fits !
If MK sell sierra hubs already drilled, then cortina hubs should fit in theory.
Ben
posted on 14/10/03 at 07:42 AM Reply With Quote
I've just fitted the MK modified Sierra hubs to my Indy. I think you would be better using the Sierra hubs as MK have designed the wishbones; length/castor/camber etc around them.
From what I can see it would be very easy to upset this relationship.
Also assuming that you have a Sierra doner car then you already have the hubs for free and MK include the cost of modifying them in the basic kit.
And as ConRod points out the Cortina ones are worth £££ which would buy you some nice shiny parts for the Indy.
HTH
Nick
posted on 14/10/03 at 07:44 AM Reply With Quote
Apologies!
Just looked at you post again and noticed you are not in fact building an MK Indy !!!
Feel free to disregard my babbling above!
Nick
ned
posted on 14/10/03 at 08:53 AM Reply With Quote
i remember someone saying that astra mk2 bottom balljoints fit a standard sierra bottom upright hole, if you want avoid drilling to fit a cortina one.
Ned.
Gareth
posted on 14/10/03 at 08:58 AM Reply With Quote
Apologies! not required Nick
I am now thinking of buying the INDY over the full locost chassis build. I may still try and shoe horn the Sierra DOHC engine in though, as the engine was cheap and brand new (1989) and even though not common there seems to be a few people trying to use them.
I will need to try and locate a good local ali welder though for the sump. If not possible to use the engine I can always sell the engine (ebay).
Gareth
theconrodkid
posted on 14/10/03 at 04:05 PM Reply With Quote
in my opion (note disclaimer) the dohc lump isnt worth a carrot,put a pinto,vauxhall or bike engine in,tin hat on dives for cover
who cares who wins
pass the pork pies
Ben_Copeland
posted on 14/10/03 at 08:02 PM Reply With Quote
Thats what i heard too john !!!!!
Ben
New Topic New Reply
