speedyxjs
posted on 5/1/08 at 02:18 PM |
Learning Electrics
What is the best book to read about car electrics. I only know the basics and ideally would like to understand more before i progress much further.
Jasper
posted on 5/1/08 at 04:33 PM |
I'd just forget it now and don't even try, I've wired up two cars now and I still don't understand it ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
posted on 5/1/08 at 04:39 PM |
I learn't a lot about my donor loom by hanging it on the garage wall following the diagrams in the manual and stripping off all the none
essential stuff.
speedyxjs
posted on 5/1/08 at 04:49 PM |
essential stuff.
Problem is im not using my donors loom. Im making my own.
posted on 5/1/08 at 04:53 PM |
There's a Haynes book called "Car Builder's Manual" by Lionel Baxter - I think he was Ron Champion's technician at
Oundle School (but don't hold that against him!). Anyway, he gives a decent beginner's guide to car electrics in that, although I
don't recommend buying a copy as otherwise it's very basic. If you can get a copy from the library then that's the best option.
Otherwise, there's another book on car electrics that's quite detailed - however I've lent it out and can't remember the
title!
(Oi! Ditch, can I have my book back now? )
Ian D
posted on 5/1/08 at 05:00 PM |
I would buy the loom. It will save a lot of problems and time.
Jasper
posted on 5/1/08 at 05:04 PM |
Sounds like a good plan to me - then just add in the Jag engine loom, and worth getting the Haynes book to. Try and get a friendly local locoster down
to give you a hand if possible too.
Confused but excited.
posted on 5/1/08 at 05:51 PM |
If you aren't using a modern engine with EFI ( i'm using an X-flow) then, Auto Electrics by Dave Westgate is a good book. I got mine for a
couple of quid off the bay. HTH.
cossiebri
posted on 5/1/08 at 06:05 PM |
Go to halfords and get one of these...
Haynes
linky
It teaches all the basic stuff &also explains ohms law,how a three phase alternator works,relays etc .Good for reference
If it doesn't fit MODIFY it!!
Cheers BriF
posted on 5/1/08 at 06:16 PM |
dont buy one! Its well easy to do, once you get your head round it
I have that car builders manual, it was an ok read.
twybrow
posted on 5/1/08 at 06:29 PM |
Get a haynes for your motor, then just make up the rest yourself. I was so scared about wiring, but when I got stuck into it, most things were
straightforward once you think about it. Just dont try thinking of the entire loom at once. Work on one circuit at a time and it falls into place.
