Author: Subject: BEC conversion
Richard.D
posted on 8/1/08 at 11:05 PM Reply With Quote
BEC conversion
Hi guys. I'm just starting a conversion on an MK from pinto to 'blade engine.
I'm gonna have a lots of questions but first I'm thinking of fuel. Do I need to buy a 'blade fuel pump? If so - is it best mounted at the back by the tank or up front in the engine bay?
Thanks in advance for the help!
All views greatly recieved!
Blackbird Rush
posted on 8/1/08 at 11:16 PM Reply With Quote
Hi Richard,
Small world... hows the conversion going?
Didn't think of this the other evning but, you could fit a swirl pot fed by another fuel pump to give you a resovoir up front that the blade pump feeds from, not sure if the blade pump is up to getting the fuel from the back of the car to the front but im sure someone on here will know....
Ash
Ash
Richard.D
posted on 8/1/08 at 11:20 PM Reply With Quote
Hi Ash,
A small world indeed. Just started the conversion this evening hence the brain doing overtime with questions and queries!
Thanks for your thoughts - gonna collect all info before I make a decision.
ReMan
posted on 8/1/08 at 11:21 PM Reply With Quote
Hi and welcome.
My Blade pump, and many others are situated by the tank at the back, no problems at all.
So yes get a Blade, or similar pump, to match your engine. There are more problems caused by using a car pump and a regulator than cures.
UncleFista
posted on 8/1/08 at 11:23 PM Reply With Quote
Carbs or injection ?
I have CBR600 carbs on my car, pump is the original Honda part fitted next to the tank, it pushes fuel the length of the car no problems
Tony Bond / UncleFista
posted on 9/1/08 at 12:48 AM Reply With Quote
On our 'blade engined "Hellfire I" we had an externally mounted (On original rubber strap) at the side of the tank. Included a small filter about 12" before going to carbs and all was fine...
HTH Steve
PS Have a look at our original build (not the rebuild - as that is ZX12R) on the website, it may help you lots.
zxrlocost
posted on 9/1/08 at 09:46 AM Reply With Quote
Hi richard yes blade pump
and I have mounted pumps on different cars at both ends never with a prob
worX
posted on 9/1/08 at 10:11 AM Reply With Quote
This will be fine for what you need:
EBAY LINK
Toady1
posted on 9/1/08 at 11:13 AM Reply With Quote
what blade engine? ive used a injected 954, also converted from pinto, and ive used the 954 pump on the bottom of the tank, works fine!
Richard.D
posted on 9/1/08 at 01:10 PM Reply With Quote
Thanks to you all for your help!
It's a 900cc blade engine with carbs so I'll get a blade pump & mount it at the back.
Thanks again.
Thanks Steve for the ebay link - I'll check it out.
