Author: Subject: Fuel Filter for '03 R1 5pw
Lee MacPherson
posted on 22/1/08 at 09:18 PM Reply With Quote
Can anyone recommend a fuel filter and where to purchase it for my '03 R1 injected engine.
Do I fit a filter before the fuel pump or just fit one after fuel pump.
PAUL FISHER
posted on 22/1/08 at 09:27 PM Reply With Quote
If your not using the oringinal R1 pump,which has a filter built in,you need a high flow rate filter specifically for fuel injection,before the pump is best,check out EBAY item number 150208922005.this is ideal for your application.
[Edited on 19/05/04 by PAUL FISHER] Rescued attachment injection fuel filter.jpg
bassett
posted on 23/1/08 at 09:58 AM Reply With Quote
Try MNR themselves or Europa spares under fueling they have a small see through bike filter for £1.50ish and sounds fine for all bike engines
chockymonster
posted on 23/1/08 at 11:36 AM Reply With Quote
I have a small low pressure filter before the pump and a high pressure filter after it.
The small filter adapts the output of the tank to the input of the fuel pump and the high pressure one is from a Ford Focus
