saigonij
posted on 24/1/08 at 01:10 PM |
Cleaming out the inside of a Plastic Coolant Bottle
I have a MKIII fiesta header/expansion/coolant bottle i want to use on my kitcar. its a bit grubby on the inside...
are there any good tips on cleaning it? it has baffles in it, so cleaning it with a high pressure hose will only clean part of it.
any good tips? ( dont have a dish washer either )
russbost
posted on 24/1/08 at 01:14 PM |
Drop some fine gravel in with detergent & water & give it a thorough shaking till your arms drop off - usually does the job!
mac1ZR
posted on 24/1/08 at 01:15 PM |
half fill wth water, then fill the rest with bleach. Worked for us!
Chris
saigonij
posted on 24/1/08 at 01:17 PM |
will the bleach make it less transulcent?
tegwin
posted on 24/1/08 at 01:20 PM |
Rumor has it that if you stick them in the dishwasher, it comes out all sparkly..
however, if your other half finds out, I will deny all knowledge!![](/images//smilies/tongue.gif)
Benzine
Put a hamster and some washing up liquid in there and shake?
RazMan
posted on 24/1/08 at 01:26 PM |
It helps if you fill the hamster with pebbles to give it more weight ......
Raz
Howlor
posted on 24/1/08 at 01:35 PM |
Wash powder also does the trick.
DarrenW
posted on 24/1/08 at 01:41 PM |
Why would you want to do that to Hammond?
[Edited on 24/1/08 by DarrenW]
saigonij
posted on 24/1/08 at 01:50 PM |
no hamster...
got a cat though.
macspeedy
posted on 24/1/08 at 02:42 PM |
sand!
saigonij
posted on 24/1/08 at 03:22 PM |
im not sanding my cat..... you mad?
smudger748s
posted on 24/1/08 at 05:13 PM |
i've have 1 from a vw polo that had rusty coloured water in it tried, bleach and allsorts.
got the caustic out made it lovely and warm and rumbled a bit ,rinsed it out ,now like brand new.
thought it might of melted but turned out fine
regards Smudger
twybrow
posted on 24/1/08 at 06:01 PM |
Denture cleaning tablets! Plink, plink, fizz, fizz - done.
posted on 24/1/08 at 06:34 PM |
As already suggested the dishwasher if you dare or failing that try using dishwasher powder and hot water . Tried most of the suggestions with limited
results , dishwaher powder worked a treat . It also works if you have oil in the cooling system. K series owners take note!
balidey
posted on 24/1/08 at 07:48 PM |
Plug chain. Aparantly it works well
