piddy
posted on 26/1/08 at 07:56 PM |
2.0 TDCi
What changes the Ford 2.0 TDCi engine from a 115 BHP to a 130 BHP?
sparrks
posted on 26/1/08 at 08:16 PM |
asked the same question to the ford field tech as far as we know its only the map and esp parameters using ford ids you can suck and blow info from
90-115 and 115-136 but cant suck and blow 136-150 st due to engine size give it a go if it doesnt work you can still downgrade it back providing you
save the session on the ids
posted on 26/1/08 at 08:29 PM |
Different maps in the ECU.
Being a supplier to Ford I visit the plant in Genk every month. When you watch the cars coming down the line they have a A3 piece of paper that tells
the operators what to put on the car. The code also has the bhp on it. The top of range TDCi Mondeos have 155bhp.
Its the same engine in the Jaguar X type as well. Next time I'm in Jaguar I'll check the bhp.
piddy
posted on 26/1/08 at 08:51 PM |
give it a go if it doesnt work you can still downgrade it back providing you save the session on the ids
Haven't got a clue what your talking about.
Thanks for the replies.
sparrks
posted on 26/1/08 at 10:02 PM |
when you connect the ford ids it asks you if you want to save all the data (maps)to the harddrive as a back up
