jacko
posted on 27/1/08 at 05:29 PM |
Bike carbs
HI all can any one tell me which bike carbs you can split to make them wider+ i want to put two more in line to make 6 in all
ie zx9r / r1 / zzr 1100 / etc
thanks Jacko
MkIndy7
posted on 27/1/08 at 05:32 PM |
Or 2 sets of Triumph tripples maybe?
Presumably if they were a 1,000cc tripples each individual carb/Tb would be larger as well.
jacko
posted on 27/1/08 at 05:42 PM |
NOw thats what i like about this site
i did not think of then there for a skyline engine ![](/images//smilies/bigsmile.gif)
cryoman1965
posted on 27/1/08 at 05:59 PM |
zx6,zx7 zx9, GSXR600 srad. zzr range
big_wasa
posted on 27/1/08 at 06:06 PM |
fire blade
MkIndy7
posted on 27/1/08 at 06:12 PM |
Here's 1 pair going shortly on Ebay:
Speed Tripple 750 carbs
They look like they could be split, but as with the others would need a new fuel rail.
I thought they might be cheeper as well, not being as in demand as the 4 cylinder ones.
jacko
posted on 27/1/08 at 06:18 PM |
Just had a look thanks
Graham
cryoman1965
posted on 27/1/08 at 06:21 PM |
The problem with triple sets of carbs is they are more difficult to join together and use as one unit operated by one throttle control for the 6 carbs
as there is no linkage between the sets of carbs.
With a quad set you would dispose of 2 x carbs. One each from apposing ends and the linkage is there to operate as one complete unit.
As for a fuel rail you could contact keith2lp from this site regads respacing with custom parts and a new rail.
You can get half descent quads for £25-£30 inc p&p
HTH
Nige
[Edited on 27/1/08 by cryoman1965]
MkIndy7
posted on 27/1/08 at 06:22 PM |
Just thought now, you might not have to split them if its 2 pairs of 3, you might be able to make up the spacings on the manifold itself if its close
enough.
cryoman1965
posted on 27/1/08 at 06:26 PM |
The problem maybe balancing the two sets to operate at the same time and with the same amount of butterfly movement.
I spent nearly a year making SS inlet manifolds for bike carbs aswell as respacing them with cusstom machined parts. This was something we looked at
for someone in Kent. The simplest way for a straight 6 is to modifie 2 sets of 4 as all the linkage was there.
IMHO 2 sets of 4 would be much easier.
Nige
jacko
posted on 27/1/08 at 08:18 PM |
Thankyou for the info .
My son and I have only just started this project so a long time before we will need the carbs we got the front suspension / engine x member in place
today ready to bolt in
Jacko
jacko
posted on 27/1/08 at 08:44 PM |
I have just had a look at Bogg Brothers web and on gallery 4 there is a inlet manifold for a straight 6 Aston martin + carbs I think the carbs are r1
can any one tell me if i am right
Jacko
MkIndy7
posted on 27/1/08 at 09:30 PM |
This is probably going to sound a daft question.. but what happened to whatever was on the car as standard?
Would it not be worth keeping that and running a Megasquirt on it?... you could be really silly and keep the turbo too ![](/images//smilies/bigsmile.gif)
jacko
posted on 28/1/08 at 05:23 PM |
HI ha ha we have 2 engines 1 with a turbo and the other with out any thing it was bought with out of ebay
one may end up in the indy you never know
Jacko
