Author: Subject: BEC help and advice needed
ragindave
posted on 28/1/08 at 07:27 PM Reply With Quote
Thanks for any advice given.
I am going to fit a bike engine to a Tiger cat.
I have decided to go down the carburettor route as this does appear to be a little bit less in the way of cost and setting up.
Could anyone tell me please of the following 3 models what year did they stop manufacturing these bike with carbs and start the fuel injection models
Fireblade
ZX9R
Yamaha R1
Do I need a new modified sump or can you get away with a baffle plate for the following.
Fireblade
ZX9R
Yamaha R1
Do I need a new clutch or can you get away with up rating the springs for the following.
Fireblade
ZX9R
Yamaha R1
Which one is the strongest when fitted to a BEC?
Any ones in particular to avoid?
Will rejetting of the carbs be required?
Thanks Dave.
fesycresy
posted on 28/1/08 at 07:33 PM Reply With Quote
Can only help on the R1.
Carbs up to 2001, baffled sump is fine and double up on the spring in the clutch.
Out of the three I'd go R1.
matt.c
posted on 28/1/08 at 07:35 PM Reply With Quote
ZX9
1. Unsure of the age thingy
2.You can baffle it if you have enough clearance. I havent so it will be a new sump for mine.
3. Just springs but time will tell with mine.
The zx9 is not the quickest out of all of them but have a look at Wadders drag times. They may suprise you!
[Edited on 28/1/08 by matt.c]
Avoneer
posted on 28/1/08 at 07:36 PM Reply With Quote
I'm sure it will be fine, but I was under the impression that the Cat was a tad on the lardy arse weight and not the ideal cradle for a BEC due it using the whole Sierra rear end.
Pat...
Avoneer
posted on 28/1/08 at 07:38 PM Reply With Quote
Oh - Blade with modded sump & baffle plate, although I think they are fine with the standard sump.
Better clutch springs.
That's what I had and it was fine.
Pat...
fesycresy
posted on 28/1/08 at 07:40 PM Reply With Quote
Three replies all picking three different engines
ZEN
Fireblade's switched to injection in 2000 with the 929. At least that is what is stated in the Haynes Fireblade '00 - '03. manual
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
mark.s
posted on 28/1/08 at 07:46 PM Reply With Quote
Avoneer beat me to it...i think the cat is a bit on the heavy side for a BEC. Is the cat the one with the whole back end of a sierra bolted upto the back end ?.....But if you do do it you wont go far wrong with a blade, zx9, R1 ect
onzarob
posted on 28/1/08 at 08:16 PM Reply With Quote
Yes it is
Tiger Butt
Tiger Butt
tjoh84
posted on 28/1/08 at 09:11 PM Reply With Quote
have a chat with zxrlocost you prob find as well he could do conversion for your about the same cost you would get parts for see this thread click me
zxrlocost
posted on 28/1/08 at 09:47 PM Reply With Quote
hi R1 carb engine no doubt about it Ive experienced most and my order goes ZX12r, R1 Carb R1 FI
its up there with the best due to its power vs simplicity
plus yes the car is heavier but no heavier than all the BEC mini driving about
Coose
posted on 28/1/08 at 10:13 PM Reply With Quote
Fit a sump baffle plate in a carb'd R1 and off you go. My stock clutch did 7000 miles of hard road and trackdays and I'm assuming it's still going strong! (the car is now sold....)
Spin 'er off Well...
mark chandler
posted on 28/1/08 at 10:37 PM Reply With Quote
893 blade
Make your own baffle, easy, old enough to not require emmisons, good power to weight.
Cheap
Once SVA'd sell on and stick in a late engine if you feel its slow or bung on a turbo.
Paul TigerB6
posted on 28/1/08 at 11:48 PM Reply With Quote
Pat...
I can confirm the rear end of the cat weighs an absolute ton!! I used two trolley jacks to get it all in place eventually on the Supercat i am building at the moment.
Seriously consider if this is the best option for you. I would imagine a BEC Tiger Cat would be pretty close to the 600kg mark rather than under 500kg. Chester Sportscars have built a ZX12R Supercat (pics on the website) but the extra torque and power of that engine will help make up for the extra weight.
ragindave
posted on 29/1/08 at 11:36 PM Reply With Quote
Thanks for the advice I had not considered the extra weight of the Tiger cat and it may well be an issue.
