New Topic New Reply
Author: Subject: Harness
Stuart_B
posted on 29/1/08 at 05:56 PM Reply With Quote
Harness
hi, what size are the bolts required for the harness??
If this did not make sense here is a picture.
sorry about the size.
theconrodkid
posted on 29/1/08 at 06:11 PM Reply With Quote
7/16 unf 8.8 min with the spec stamped on the head
who cares who wins
pass the pork pies
posted on 29/1/08 at 06:16 PM Reply With Quote
Normally 7/16UNF. Some harnesses (Sabelts) use 8mm HT 12.9 bolts instead.
... but 99% 7/16 UNF as ^^^^^^^^
Stuart_B
posted on 29/1/08 at 07:58 PM Reply With Quote
Thank you, i wil see if i can get some if they do not come with the harness.
Stuart
zxrlocost
posted on 29/1/08 at 09:47 PM Reply With Quote
they will most likely come with three lines one the top this is the equivalent of 8.8
lotusmadandy
posted on 30/1/08 at 11:48 AM Reply With Quote
the threads are 7/16ths on the mk chassis
if you have trouble getting them,the seat belt bolts from your sierra donor car fit the threads and are 8.8 ton.
paulmw
posted on 30/1/08 at 01:21 PM Reply With Quote
I got some Willians harneses that only come with the top eye bolts.
I got some 7/16 bolts for the bottom from Tifosi today for £1.50 each. Give them a buzz 01769 581 454
Stuart_B
posted on 30/1/08 at 01:36 PM Reply With Quote
where are Tifosi located?
paulmw
posted on 31/1/08 at 08:10 PM Reply With Quote
Devon, me thinks
Stuart_B
posted on 31/1/08 at 08:14 PM Reply With Quote
Bit far for me.
New Topic New Reply
