marcotuinenburg
posted on 31/1/08 at 09:56 PM |
Are Tyraps enough for SVA to mount my loom to the chassis ?
I have done spiralwrap all around the loom now and am thinking how to hold it to the chassis.
Is it SVA proof to use plastic tyrips or do i need to fasten the complete loom in the same way as the fuellines and brakelines are mounted ?
Thanks, Marco
bigrich
posted on 31/1/08 at 10:13 PM |
tie wraps are fine for SVA but i would use them with the small plastic screw down saddle mounts instead of just aound the chassis
Rich
posted on 31/1/08 at 10:15 PM |
Most of my loom is fixed with tie-wraps, usually to those stick-on pads designed to attach to flat surfaces. The only thing they require is a
pop-rivet or screw into the surface to ensure that they don't come unstuck (most have a hole for that purpose).
You will require some form of covering for the loom - I used spiral wrap, but that's a pain. If I was doing it again I'd use split
convoluted tubing.
HTH,
stevec
posted on 31/1/08 at 10:21 PM |
I agree with the cable bases.
Edited to say that I also riveted them on.
linky
[Edited on 31/1/08 by stevec]
nitram38
posted on 31/1/08 at 10:27 PM |
I secured my entire loom (spiral wrapped) with cable ties directly to the chassis.
No problems passing.
posted on 31/1/08 at 10:31 PM |
I nearly failed my SVA because the inspector was concerned about those stick-on pads - fortunately I was able to show him that almost all of them were
pop-riveted securely. Some weren't but I was able to satisfy him by tie-wrapping that part of the loom direct to the chassis.
dhutch
posted on 31/1/08 at 11:58 PM |
Yeah, the sticky back on the bases is shocking. Lasts hours not years.
- However i wouldnt expect them to have an issue with tiewraps themselfs, or bases attaced by other ways.
- After all, this is what main stream manufactors do in production cars. If the looms are secured to anything at all.
Daniel
Macbeast
posted on 1/2/08 at 06:14 AM |
If you're going to pop rivet the tie-wrap bases, why not use black plastic P clips instead ?
Much neater IMHO
RazMan
posted on 1/2/08 at 08:13 AM |
I roughed up the bases of the cable tie bases and put a dab of PU adhesive in place of the foam pads - they are fairly permanent that way and will
also stick to fibreglass panels where the foam pads haven't a chance. I prefer not to drill holes in my nice painted chassis whenever possible
Raz
ditchlewis
posted on 1/2/08 at 08:20 AM |
As David J says^^^^^^ they like the cabel tie bases but they like them mechanically fixed.
i also nearly failed, because i missed one and that was the one he checked![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) i ended up showing him more and they were all screwed to the
chassis![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/tongue.gif) .
ditch![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
posted on 1/2/08 at 08:36 AM |
Much neater IMHO
Because with the tie wrap bases you have the option of removing the loom (e.g. to add extra wiring) by simply cutting and replacing the tie wrap. If
you use P clips you have to drill out the pop rivet and have even more junk rattling around inside the chassis.
mad4x4
posted on 1/2/08 at 09:48 AM |
Rich
I failed my SVA for putting the loom in a tyrap and then round the chassis. www.Maplin.co.uk do small clips with a hole that you can pop rivet onto
the chassis and then tyrap to. You can also get sticky ones as well (but these come off too easily)
Scot's do it better in Kilts.
