Author: Subject: Could you use this as a donor?
emsfactory
posted on 1/2/08 at 09:53 AM Reply With Quote
I'd like to.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=260207971390&ssPageName=STRK:MESE:IT
speedyxjs
posted on 1/2/08 at 09:58 AM Reply With Quote
Might need a new wheel
Only problem is the service intervals are about 6000 miles.
Would be good on the drag strip though
Davey D
posted on 1/2/08 at 10:00 AM Reply With Quote
It would be easier as a Mid/Rear engine setup, so you can keep the engine transverse, as i dont think there are any setups using that engine longditudionally
chockymonster
posted on 1/2/08 at 10:42 AM Reply With Quote
No they aren't!
The engine service intervals are 10-12k
The rear diff service intervals are 4.5k (service entails checking the oil level in the bottle in the boot and actuating the diff whilst the vehicle is on a 4 poster lift to check for air locks)
DarrenW
posted on 1/2/08 at 11:42 AM Reply With Quote
Now that would make a quick car. I was talking to a locl guy who was planning on using an evo engine for a se7en. Madness i say
Do you think it will polish out? Might need G3 though.
[Edited on 1/2/08 by DarrenW]
Werner Van Loock
posted on 1/2/08 at 12:21 PM Reply With Quote
Don't like this though:
WE HAVE HAD THE CAR RUNNING BUT DUE TO OIL COOLER DAMAGE NOT FOR LONG
Don't know how the oilcooler is plumbed in on the evo, but most use a takeoff plate between oil filter and oilpump so they ran it probably without oil pressure
http://www.clubstylus.be
Miks15
posted on 1/2/08 at 02:58 PM Reply With Quote
i suppose you would need to check the front upright for damage if you intend on using them?
IM sure uve thought of that and im just stating the obvious but justr in case
posted on 2/2/08 at 12:11 AM Reply With Quote
Originally posted by emsfactory
I'd like to.
If you can afford to think of using that for a donor you're definitely in the wrong place I think
colt_mivec
posted on 2/2/08 at 01:40 AM Reply With Quote
No they aren't!
The service intervals are every 4500miles I owned an evo 8 in 2006 for 8 month,Sold it due to high running costs
