roadrunner
posted on 3/2/08 at 04:34 PM |
zx9r wiring dilema part two
Now that i have sorted my headlamp problem i still have no spark , i have tested the voltage at various places across the loom and all seems ok, i
even have voltage at both wires leading into each coil stick, has anyone any ideas, am i supposed to have a voltage at both wires leading into the
coils, or does it mean something else is wrong.
Thanks Brad.
Mark G
posted on 3/2/08 at 04:42 PM |
have you remembered to earth your engine to the chassis?
roadrunner
posted on 3/2/08 at 04:58 PM |
Thought of that, and yes it seems to be a good earth.
cossiebri
posted on 3/2/08 at 05:37 PM |
Brad try this, with the ign on disconnect the smaller plug off the ecu (To coil packs)then reconnect and try and start. This is what i had to do when
i had the same symptoms as your descibing
If it doesn't fit MODIFY it!!
Cheers BriF
bigrich
posted on 3/2/08 at 05:46 PM |
if the wires are attached to the coils then both sides will show voltage but if the wires are disconnected from the coils and are both still live you
have a problem.
It sounds as though the ecu is not switching the coils on and off which could be a anti hot wire(grey wire 100ohm fault) or poss a crank sensor fault
so the engine does;nt know its spinning over
dan__wright
posted on 3/2/08 at 07:13 PM |
i had this problem on my zx10, everything come on but no spark, it was to do with the starter lockout circuit, check everything on that circuit.
was v strange as injectors fired but no spark
FREE THE ROADSTER ONE…!!
roadrunner
posted on 3/2/08 at 07:45 PM |
Tried this thanks Bri, but still no spark.
roadrunner
posted on 3/2/08 at 07:49 PM |
if the wires are disconnected from the coils and are both still live you have a problem.
I tested this Rich, i disconnected the coils and only got a voltage through one of the wires, i also checked the grey wire with the 100ohm resistor
and everything seems fine and dandy, as for the crank sensor there is'nt one, did you mean the cam sensor.
roadrunner
posted on 3/2/08 at 07:50 PM |
What do you mean by the starter lockout circuit Dan.
Another thing, does the passing switch need to be earthed, as mine is not.
bigrich
posted on 4/2/08 at 10:50 AM |
I did mean the crank sensor, it may be listed as inductive pulse pick-up and if its colour coded like my zx10r then its a red/black wire and a black
wire which should be fitted inside one of the crankshaft end covers
