tim windmill
posted on 11/2/08 at 09:14 AM |
what cat convertor
still struggling with emisissions to meet sva requirements, can anyone tell me what cat have you used on a 2.0l blacktop zetec for sva
Mr Whippy
posted on 11/2/08 at 09:22 AM |
do you have one on already? if so perhaps it's not getting hot enough and could do with some thermal wrap?
tim windmill
posted on 11/2/08 at 09:44 AM |
yeah got one off a 1.4 fiesta that i have borrowed and i know that ity has gone through an sva on a bec zx9 without being wrapped but when the test
was donbe with it mounted on my car set up the machine came up with an error sying that thye gas flow was to low.
ican get it to idle with 0.3hc and at 2500/3000 rpm i can still get a reading of 0.3 but it runs very hot and cannot the get a reading for a cat
test.
seriously thinking about cancelling my sva until i can get sorted its a week on Wednesday 20/02/2008. i have got access to a trailer and would like
to take it somewhere to be set up so that i am confident that it would meet emmisions for sva. Could it be set up using a wideband sensor to meet the
sva requirements using my existing set up? Any help greatly appreciated
piddy
posted on 11/2/08 at 04:26 PM |
Hi.
Did I read on one of your previous threads that you’re using mega Squirt?
I’m running a 1.8 Silver top Zetec I borrowed a 1.8 map from someone and got the car running using this. I drove it to the MOT (Done by a friend) and
the emissions were miles out we played with the settings in the map until the car passed the emission with ease.
A week later I took the car for it’s SVA and it wouldn’t have passed the emission test if it hadn’t been for the lenient tester he let us adjust our
map setting until the car passed. The emissions had change big time for some reason.
This got it through the SVA but I wasn’t really happy with the way the car ran and the fuel consumption so went and brought an LC1 and wideband
sensor. This has made the car a lot better reduced the fuel consumption and I’m sure reduced the emission reading. I think that and LC1 is the way for
you to go, if you don’t get one now you will later (that’s if you are using Mega squirt)
I’m still not sure that a 1.4 Fiesta Cat is man enough for a 2.0 Zetec.
tks
posted on 11/2/08 at 11:46 PM |
that error is not logical to follow on a running engine isn't it???
i mean wy not enough flow???
if it would say values of gas out of scale??
but not enough flow????
Tks
Stu16v
posted on 12/2/08 at 09:56 PM |
The 'low flow' is probably down to the probe on the emissions machine starting to melt - seen it before! Another sign is a sudden increase
in hydrocarbons, as the plastic pipe begins to degrade...![](/images//smilies/shocked.gif)
