Author: Subject: 32x343mm discs?
Toady1
posted on 25/2/08 at 09:47 AM Reply With Quote
32x343mm discs?
anyone know where to get some replacement discs for a f50 brake kit from? they're 32x343mm discs that bolt to an alloy bell. AP are about £500!!!!
Fred W B
posted on 25/2/08 at 11:26 AM Reply With Quote
Wilwood may do something similar. Try Rally Design
Fred W B
Lippoman
posted on 25/2/08 at 04:43 PM Reply With Quote
Brembo or AP
Is this a replacment for the original F50 Brembo rotors or for a AP racing brake system for the F50?
343x32 seems odd, F50 is supposed to have 355x32 Brembos iirc, replacements for these can be found for about US$250/each (disc only) f.ex. http://www.zeckhausen.com/Brembo/Consumables.htm
Toady1
posted on 25/2/08 at 11:42 PM Reply With Quote
Its for my skyline. It has an F50 brembo 4 pot conversion. the discs are either 340 0r 343mm dia x 32mm thick.
lippoman - good site cheers! But not sure if they will fit my bells. I rang GPR today, and was told theyre the GT1 spec brakes and ill be looking at around 250-350quid each disc!!!!!!!
[Edited on 25/2/08 by Toady1]
Lippoman
posted on 26/2/08 at 07:44 AM Reply With Quote
The StopTech AeroRotors listed at Zeckhausen are supposed to be replacements for the Brembo discs in the so-called F50 kits. (bell fitment by 10 times 8mm lugs at dia 233). The flange inner dia differs though, 209 for Brembos and 213 for the StopTechs.
Strange that your discs are 32x343, Brembo lists 32x355 for their Gran Tourismo kits for the Skylines (R32,R33 and R34). Which size wheels are you running?
Do you have the Brembo kit or disc part number?
