Gergely
posted on 26/2/08 at 11:25 AM |
Ordering MNR VortX soon! Help spec it!
I can't believe the day is soon to arrive! In a team effort with my brother and dad we decided to order an MNR VortX! We hope to have the car
ordered in March-April time. We need to finalise the specification and double check legislation in Hungary to make sure nothing goes wrong, but up to
now we are GO!
Here is the initial specification below. I would like to ask you knowledgeable lot to help and point out areas where I should stick to lower
specification to save costs or go to higher specs because I will simply regret not doing it later.
The guideline for the car is: Light and quick road and track car, but locost. We don't want to spend on anything that doesn't make the car
quicker or better handling (maybe one or two exceptions of course... ), but also don't want to spend a fortune to make it just a couple of kgs
lighter.
So here are the specs:
- MNR VortX RT Inboard kit
- Yamaha R1 fuel injected engine (2005-2007? not sure yet, depends on price, the higher bhp the better... - recommendations?
- 3.38 or 3.62 diff - I have to see what is available in Hungary... costs are low here, a diff costs around 25-30 GBP
- Racelada front end (uprights, hubs, discs, brakes - the whole lot) - can someone confirm they are worth it when compared to the std Cortina
setup?
- Paddle shift kit
- Quick rack
- Momo Mod.26 steering wheel
- MNR composite seats
- Sabelt 4 pt. quick release seatbelts
- R1 instruments with additional switches and lights if required, but bare minimum to pass SVA
- 13" alloy wheels - if they fit the Racelada front and Sierra rear discbrakes... any ideas here? What wheels are recommended? We would like
black or anthracite.
- Toyo R888 tyres
This is the main spec, the rest (lights, mirrors, etc, etc is not very important in the sense that those don't matter too much in the
performance of the car.
What do you reckon? Any ideas, suggestions welcome! What would you change / do differently, include for sure or drop from the list?
Thanks guys!!
Gergely
Paul TigerB6
posted on 26/2/08 at 11:40 AM |
The R1 will be a good choice especially as it allows you to use a standard MNR exhaust. You might also consider the ZX12r as they have the exhausts
advertised and it gives a bit more power (but maybe not worth the extra cost once you sort out the sump)
One thing i'd definately go for is a 4-2-1 exhaust.
As for wheels - Compomotive CXR or Team Dynamics Pro Race 1.2's??
worX
posted on 26/2/08 at 11:55 AM |
Compomotive CXR's in 13"s...
I'm not sure whether I would go for the Raceleda front end if you could easily get hold of Cortina stuff? I would use the Cortina Uprights and
just replace the hubs with some nice Ali ones...
posted on 26/2/08 at 12:23 PM |
This is just my opinion so take it or leave it please.
I reckon the Raceleda uprights are just a bit bling.
I couldn't see any advance over my Sierra donor uprights. OK they are lighter but any better for a road car? Probably better for a race car, but
better than Cortina uprights with light alloy hubs?? IMO not worth the extra cash.
Quick rack is included in the kt when you submit a donor part for modification.
Quick release seatbelts may be a problem for SVA... I'm using clubman road legal harnesses.
Wheel size is surely a personal point. I have 15" TD Pro race 2 on mine which are supposedly very light. I also have the original 14" Ford
alloys off the donor. Not a good choice but hey, they came free with the Sierra!
Good choice of kit anyway![](/images//smilies/bigsmile.gif) hope you enjoy the experience! good luck
Gergely
posted on 26/2/08 at 01:03 PM |
Thanks guys!
Why? What is the advantage, could you please explain?
Point taken for the Racelada upright and ali hub. Probably the full front end is too bling... true. How about the brakes then? Should I stick to the
Cortina brakes? Or is there any real advantage in changing to Racelada or similar?
I will most probably not be able to submit donor parts for modification, but buy the modified parts from MNR. quick rack included.
Seatbelts - Point taken, I want proper 3" harnesses with quick release for easy exit, maybe changed for something else (borrowed) for SVA...
Compomotive and TD wheels - Yes I like them... but they are a bit pricey aren't they... any other options?
Keep the ideas and comments coming please!
Which R1? Which diff? What wheels - 13, 14 or 15"?
Thanks!
Gergely
bassett
posted on 26/2/08 at 01:05 PM |
What sort of use are you planning for it? If its the track stick with the raceleda front end. If its for the road the standard MNR fabricated cortina
uprights with aluminium hubs and wilwood calipers are still pretty light and are a lot cheaper. If you dont like wiring MNR can supply a loom which
might save some hassel. If you need it you'll also have to spec reverse i think another £700.
You can use old ford wheels but once youve got new tyres and cleaned them up whats the point. The TD wheels are cheap and light but every other car
has them fitted over here. I've gone for black TD 15's a good compromise for looks and handling but 13's might be more suited for
the track. As for the engine buy older versions for simplicity or new ones for more power. I think the commonly used diff for R1's is the 3.38
but might be worth considering an lsd variant. Other than that its a great kit so go for it.
Adam
[Edited on 26/2/08 by bassett]
Gergely
posted on 26/2/08 at 01:19 PM |
It will be more for the road with 3-4 trackdays per year. I think I am confused... Which is the MNR fabricated upright kit? I thought it was original
Cortina or Racelada... have I missed something?
The loom is probably worth it... will discuss with the team... I have not done any wiring before...
As for reverse, the idea is to skip it for a start, see if we can't live without, in which case we'll try to fit a self-made electric
reverse.
I don't care how many cars have which wheels fitted, I will have the first MNR in Hungary as far as I know...
I think 13" for handling would be preferred to 15", but only if they fit for sure over the calipers... can someone confirm 13"
wheels are OK? Or let me know which ones are OK, which not...
Thanks!
Any other pointers? Ideas? Suggestions? Keep them coming!
[Edited on 26/2/08 by Gergely]
markyb
posted on 26/2/08 at 04:16 PM |
I have to say that you have made an excellent choice with MNR as they have continued to exceed my ecpectations.
Going by what I have read on this site your choice of wheels, diff and engine are inter related as the wrong choice can make driving less than
satisying in low gears.
Somewhere on this site there is a gear calculator (someone will probably be along shortly with the link !!!) in XLS format.
Once you have this try different settings
for wheel size, diff and engine to see what impact these have on gears and speed
sucksqueezebangblow
posted on 26/2/08 at 04:20 PM |
I went for the 13" CXRs with Toyo R888s they look the dogs and MNR can supply. I also went for the Raceleda front end. If you are going to save
weight go for unsprung weight first as it will pay dividends in handling.
bassett
posted on 26/2/08 at 07:48 PM |
With the uprights i dont think MNR use the original cortina stuff. You have the basic cortina uprights design which i think are steel fabricated then
powder coated with the large ally hubs(not on the site) like the originals or their super light weight ones which are coloured red and gold on their
site.
road warrior
posted on 26/2/08 at 08:37 PM |
With regard to engine choice.
The 06 R1 engine has slightly better gearing than the 05. The 07 is quite a lot taller because of the airbox so you will need a bonnet scoop. An 06
will fit under the standard bonnet ok with a foam filter with a slight mod to the base.
What colour and what style nose are you thinking of?
Sonja
Krismc
posted on 26/2/08 at 08:47 PM |
Raceleda uprights, hubs and brakes are a very resonable cost considering what you actually get and the spec of them also if you try holding one
cortina upright and hub in 2 hands then try holding 2 raceleda ones with discs you will understand the differance!
uprights, hubs, bearings, callipers, disks, pads and fixings for arouns £600-£700 is cheap i recon
Gergely
posted on 26/2/08 at 09:05 PM |
markyb - yes, I have the calculator, that's a great tool, thanks. I was just wondering what other people thought to get as much info as possible
and adjust accordingly.
bassett - Thanks for the info, I will check the uprights question with Marc then to clear things up.
Sonja - Thanks. It seems '06 engine is a good choice then. Although one question: would I lose any power by using the foam filter as opposed to
the airbox as used by the bikes originally? If yes, I probably need the scoop anyway, correct?
What is the slight mod to the base of the '06 engine you mention?
As for colour I am not sure yet... we need to fight over that I guess. I like the usual suspects: orange and red personnally, but we will have to vote
or something...
I am thinking it will have the new nose. It just looks more complete to me. And more "tough", also a little less kitcarish...
Krismc - This is exactly the reason I thought about them in the first place. If I need to have all that is in the kit, preferably new or in a great
condition, I would not be too far from the Racelada kit I reckon... I will discuss this with Marc.
Thanks all! Any more ideas, suggestions, experiences to help with my specification?
Exhaust end cans for example: should I buy a fabricated one from MNR or get the corresponding Yamaha one?
Gergely
chockymonster
posted on 3/3/08 at 05:28 PM |
Gergely,
I'd be looking at the earlier engine (2003-2004) 5PW
The gear ratios are more usable in a car setup.
