cossiebri
posted on 26/2/08 at 05:50 PM |
R1 wiring
Has anyone got a photo of the wiring going into the regulator/rectifier for the 4xv R1? As i'm not using the original loom need to know what
goes where from the 5 pins,i know 3 go to alternator 1 to earth & 1 to main fuse in starter relay.Need to knowwhich ones
cheers
[Edited on 26/2/08 by cossiebri]
If it doesn't fit MODIFY it!!
Cheers BriF
smart51
posted on 26/2/08 at 06:07 PM |
on mine, red is 12V, black is ground and the three whites are the 3 phases of the generator.
cossiebri
posted on 26/2/08 at 06:08 PM |
But where are they on the plug that goes to the reg/rectifier? As i haven't got the loom just the main reg/rect unit with a 5 pin plug on it
Cheers BriF
locoR1
posted on 30/3/08 at 10:37 AM |
Here you go all three whites on the bottom three connections red to the right and black to the left depending on which way you look at it see
photo!
And nothing connected to the top center.
[img] [/img]
Dave.....
![](/galpreviews/cafe racer 1.jpg) ![Description](/gallery/cafe racer 1.jpg) Description
Check out my CB500T Cafe Racer build diary
cossiebri
posted on 31/3/08 at 03:20 PM |
Cheers for that dave, you are a star
Cheers BriF
locoR1
posted on 31/3/08 at 03:26 PM |
Your most welcome![](/images//smilies/wink.gif) ![](/images//smilies/wink.gif)
