finlay
| posted on 27/2/08 at 08:54 AM |
best way to remove sticky tape from tub
hello all
i have got the remains of the brown parcel tape stuck to my body tub where it was wrapped in bubble wrap, if it was metal i would use a bit of heat to
remove it but is fibre glass
has anyone else had this problem and what did they use to remove it ?
any suggesstions ?
cheers
Bluemoon
| posted on 27/2/08 at 08:57 AM |
WD40 Worked for me..
Baby oil might be worth a go..
Dan
indykid
| posted on 27/2/08 at 09:00 AM |
brake cleaner
tom
Kaspa
| posted on 27/2/08 at 09:01 AM |
any citrus type cleaner , ie some dish washing liquid has lemon in it , that will do it , and wont harm the paint work
cheers kaspa
understeer= when you hit the wall front first
oversteer=when you hit the wall back first
HP= how fast you hit the wall
Torque= how far the wall moves when you hit it
thunderace
| posted on 27/2/08 at 09:05 AM |
kettle and hot water works .
Mr Whippy
| posted on 27/2/08 at 09:06 AM |
white spirt, does not harm to glass fiber but desolves sticky glue
gr8ging
| posted on 27/2/08 at 09:40 AM |
WD40 worked for me also. I was recomended it by a friend who works with fibre glass. I wouldn't use a solvent it may dull the finish.
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
DarrenW
| posted on 27/2/08 at 09:52 AM |
I think WD40 contains kerosene which is sometime used as a degreaser (its certainly used to clean parts in bearing plants). This si why WD40, whilst
an effective water displacer is not good at long term rust prevention.
| posted on 27/2/08 at 10:15 AM |
paraffin or white spirit to dissovle the glue.
a hair dryer will soften the glue to allow it to be puilled off; it will not damage grp - not to be mistaken with a heat gun which probably will.
iscmatt
| posted on 27/2/08 at 01:10 PM |
i did this too! whoops - white spirit and a clean cloth, no probs
wax-it
| posted on 28/2/08 at 02:19 PM |
ANY oil based product will help to remove the sticky substance, but isnt ideal for paintwork.
Hairdryer and warm water works for me.
