locoboy
posted on 27/2/08 at 07:45 PM |
reccommend me a tool!
Can you guys recommned me an extractor of some sort to remove a broken off bleed nipple?
I Have a poo quality set of screw extractors of which the 2 smallest sizes are broken and it would be one of them that i need.
Are there any decent quality ones about?
All the ebay ones are about 2.99 a set so they will be equally as shite as mine!
Locoboy
mookaloid
posted on 27/2/08 at 07:49 PM |
Had several broken bleed nipples in my time. Easy outs never work
I would suggest trying the 'weld a nut on with a mig welder' trick - this method has never failed me for any broken stud
HTH
Mark
r1_pete
posted on 27/2/08 at 07:52 PM |
Yep, best place for extractors is the bin, they are smaller diameter than what has broken off so logic says they will break off too.
Ditto the weld, if you have an arc welder, you can gradually build up enough to slip a nut on, then weld that up. The heat assists with the removal
too.
posted on 27/2/08 at 07:54 PM |
I would also weld on a nut. Either that or an exchange caliper
locoboy
posted on 27/2/08 at 07:57 PM |
I seem to be ammassing a garage full of broken things at the moment, my welder is up the swanney because the seal has gone in the gas block / valve
and thats £25 to replace that!
The callipers are spares that i was hoping to spruce up and sell on.
Looks like my callipers are going to pay for the welder repair then doesnt it!
Thanks i will get the welder fixed then try and fix the callipers and throw the easy outs in the bin
Locoboy
snapper
posted on 27/2/08 at 08:02 PM |
I would normally batter the offending item with the biggest hammer i had then go down the pub and be ridiculed by my mates.
However if it had not broken and when i had sobered up i would use bigger and bigger drills to open out the offending nipple then try the easy out
again.
You can also use a diamond tipped dremil bit to get as close to the threads as you dare, by then it will come out easy.
Or you can get another caliper, fit it and drive off then try my suggestions on the offending caliper, get anoyed, beat it with a big hammer, go down
pub, get ridiculed by mates etc. etc.
I eat to survive
I drink to forget
UncleFista
posted on 27/2/08 at 08:34 PM |
If it was me, I'd have a go with some left-handed drill bits
Tony Bond / UncleFista
foskid
posted on 27/2/08 at 08:50 PM |
get a decent set of extractors, they do work. but for a locost version, drill it open a bit and use the tang of a small file - tap it in with a light
hammer and turn with an adustable spanner. worked for me.![](/images//smilies/wink.gif)
triumphdave
posted on 27/2/08 at 09:23 PM |
This usually works for me too.Or grind a slight tapered square on the end of a allen bolt bash it in and use a key( you need to get the square a good
fit in the hole with only a slight taper)
posted on 27/2/08 at 09:28 PM |
http://www.agriemach.com/default.php?cPath=0_63
![](/galpreviews/a700347-D1230BrakeBleederScrewKit.jpg) ![Rescued attachment D1230BrakeBleederScrewKit.jpg](/gallery/a700347-D1230BrakeBleederScrewKit.jpg) Rescued attachment D1230BrakeBleederScrewKit.jpg
robinj66
posted on 27/2/08 at 10:48 PM |
Locoboy
I had a leaky gas valve on my Mig. turned out the connecting part was slightly oval. Bit of care in a vice and it was OK to use (might save you £25).
To make sure i didn't waste a whole bottle of gas, i just removed the bottle completely each time i had finished.
posted on 28/2/08 at 08:56 AM |
that is good in theory but hardly any drill presses spin anti-clockwise.
as areay said, clmp it up in a drill press and carefully drill out using successively larger bits.
thomas4age
posted on 28/2/08 at 09:35 PM |
trident, Thats what racelade uses on their calipers, and seems very neat and safe to opperate.
at least you'll have 2 chanses if it goes completly wrong.
for removal,
drill it out to the biggest diameter you feel safe at(don't damage the threads), tap in a flat screw driver and turn it out with that, worked
for me 2 times now.
Grtz Thomas
If Lucas made guns, Wars wouldn't start either.
posted on 29/2/08 at 06:13 PM |
If you weld a nut on and it doesn't work (will be suprised if it doesn't) you can always grind the weld off and drill /easiout. but if you
drill it wrong or break an easiout???
