Author: Subject: crankcase breather hose size
bobster
posted on 1/3/08 at 10:16 PM Reply With Quote
is an 8mm hose adequate for the crankcase breather hose?
mark chandler
posted on 1/3/08 at 11:02 PM Reply With Quote
1" would be near the minimum size. Crank case prssure costs you power and worse case pushes out seals.
Regards Mark
mark chandler
Regards Mark
posted on 2/3/08 at 09:21 AM Reply With Quote
1"
I'd need to measure to be 100% sure but think have 10 mm or 1/2 " on the crossflow and v8 which are same dia. as original fittings.
posted on 2/3/08 at 10:04 AM Reply With Quote
The gizmo I bought from Burtons and fitted to my x-flow block has a 1/2" outlet. If I could be bothered to fit an oil filler cap with a breather outlet then that would be 1/2" too.
The original pipe that went from the now-removed PCV to the inlet manifold was smaller, IIRC.
[Edited on 2/3/08 by David Jenkins]
MkIndy7
posted on 2/3/08 at 11:36 AM Reply With Quote
That will have had vacume pressure from the inlet helping it draw the fumes tho, rather than them naturally venting.. hence the other requireing a larger diameter pipe.
