Author: Subject: Shock mount in single shear - OK?
blueshift
posted on 7/3/08 at 07:32 PM Reply With Quote
Hi chaps, just after opinions or even engineering facts on whether it's ok to mount my rear shocks on an M12 bolt in single shear, on the axle.
Like AdamR has here:
http://www.locostbuilders.co.uk/viewthread.php?tid=78935
Ta
Mal
posted on 7/3/08 at 07:56 PM Reply With Quote
Damper Mountings
Westfield rear dampers are mounted onto the top of the rear upright by a 7/16"UNF (11mm) bolt in single shear, so I think you will be alright.
Mal.
SPYDER
posted on 7/3/08 at 09:04 PM Reply With Quote
Use NEW bolts, preferably 12.9 rated capheads. How long are the bolts in question. I could probably post you a couple.
Geoff.
ReMan
posted on 8/3/08 at 07:38 AM Reply With Quote
Many older bikes had a single shear stud fixed to the swingng arm for the lower mounting
flak monkey
posted on 8/3/08 at 07:45 AM Reply With Quote
Yes its not a problem. Too early in the morning to be bothered to do the maths, but if you do a search I have posted figures for the yeild and UTS of various sizes of bolts in single and double shear over before.
Sera
http://www.motosera.com
ch1ll1
posted on 8/3/08 at 11:26 AM Reply With Quote
thats what i did on mine !
