Author: Subject: Engine Cleaning/ Ultrasonics?
T1GER_SUPERCA7
posted on 10/3/08 at 02:17 PM Reply With Quote
Gents,
I have stripped my 2L Zetec and have started the painful task of degreasing and cleaning.
Has anyone used an ultrasonic cleaner for cleaning blocks? heads? pistons etc? Is this a sensible option? We have one at work and it seems like a good option.
Would I be able to ultrasonically clean the block? in addition the block is fairly rusty inside the coolant channels and reservoirs? is this ok? I am happy with the block as there are still honing marks on the bores but should I be re-honing to deglaze them?
Many thanks, any advice would be helpful.
Chris
vinnievector
posted on 10/3/08 at 03:20 PM Reply With Quote
Hi mate
Hi mate ,there should be no probs with this at all ,i have cleaned up many parts inc my carbs and have had no problems .
if its free use it as this is the best sort of degreasing available and the latest tec .
Mix
posted on 10/3/08 at 05:15 PM Reply With Quote
In my experience the 'degreasing' ability of an ultrasonic bath is dependant on the solution used. Give it a go by all means but expect to have to manually remove paint, corrosion etc. Ultrasonics are really about shaking loose small particles.
Mick
