MB
posted on 3/11/03 at 10:19 PM |
Ally countersink
I'm attaching some ally rounded strip to my car and am having problems with countersinking..... basically I keep on having to scrape out ally
from the cutters as it gets clogged up. I've got about 20 holes to countersink and each half a countersink I need to scrape the countersink
clean. It's taking ages!
Am I using the wrong tool???
Mark Allanson
posted on 3/11/03 at 10:31 PM |
Ally does tend to stick to any cutting tool unless you use loads of cutting oil, screwfix do a good aerosol one very cheap
posted on 4/11/03 at 02:13 AM |
Not only a suggestion...
Speak to any engineer used to cutting Aluminium years ago, and he swore by paraffin...
... and until it was realised that it was a REALLY dangerous fire hazard it was still used. It does give the best finish available, just use a little.
But put you're Cig's out before you use it!!!
MB
posted on 4/11/03 at 09:23 PM |
Excellent - a supply of cutting oil makes a huge difference. It's doesn't make the problem go away, but at least I can cut a lot more
metal before having to stop and clean up the cutter.
MustangSix
posted on 4/11/03 at 09:30 PM |
I've used beeswax or soap with good results, as well.
[Edited on 5/11/03 by MustangSix]
flyingkiwi
posted on 7/11/03 at 11:38 AM |
What type of countersink are you using?how big are the holes and is the countersink sharp. I've found that even with cutting oil is you try to
drill too quickly the result is a mess, plus a blunt bit will clog up quickly. I could be barking up the wrong tree here but are you drilling holes
for rivets? If so a hand drill or a slow speed electric drill should help. Get a bit of offcut and try different speeds, or have the bit resharpened,
it might help
[Edited on 7/11/03 by flyingkiwi]
It Runs!!!!! Bring on the SVA!
DaveFJ
posted on 7/11/03 at 12:21 PM |
I'll second that - I would personnally ONLY ever countersink using a hand brace and a 'proper' countersink tool....
Dave
paulf
posted on 9/11/03 at 04:58 PM |
WD 40 is a very good cutting fluid for allumium and easier to use and more likely to be to hand. We even used it in machine shops in preference to
cutting oil as its much cleaner.
Paul.
Alan B
posted on 9/11/03 at 06:20 PM |
Yep, agreed....WD40 is used in every shop I've ever been in over here for machining ally....usually bought in the gallon tins and put in a hand
squirter.
posted on 9/11/03 at 06:48 PM |
I use a cheap version of WD called AC90 when drilling ali or cutting it with the nibbler and it keeps things clean. I used a countersink designed for
woodwork on mine, as it was HSS it worked o.k. It was a bit with a plastic handle, not drill mounted, just use it like a valve grinding stick.
yours, Pete.
posted on 11/11/03 at 02:42 AM |
& it's almost as flammable!!!
