iiyama
posted on 12/3/08 at 07:31 AM |
Wheel spacers
Wheels I have are ET 40mm. This is fine for the rear, but the front require ET9.5. So am I right in thinking I need 30mm spacers?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
posted on 12/3/08 at 08:11 AM |
I would agree. The larger the positive ET the less dished they are so you want to push them out hence the spacer.
.... but it is early in the morning and my brain has not warmed up yet so small chance I could be worng.
chunkytfg
posted on 12/3/08 at 09:17 AM |
would you not need a 30.5mm spacer?
![](/images//smilies/bigsmile.gif)
iiyama
posted on 12/3/08 at 10:30 AM |
I guess, but the .5mm I can get away with!
Anyway as long as I have the right understanding! Thanks guys!
hobbsy
posted on 12/3/08 at 10:57 AM |
U2U sent as I have a pair of custom made ally hubcentric 25mm ones going spare which might be close enough for what you need?
minitici
posted on 12/3/08 at 03:13 PM |
If you are considering competing in your car, be aware that you are limited to a single spacer of 25mm maximum.
iiyama
posted on 12/3/08 at 06:37 PM |
Got em the wrong way round, spacers required on the rear!
Wasnt aware of the spacer issue for competing. Is that 25mm overall track or 25mm either side?
