bjw970s
posted on 15/3/08 at 08:49 PM |
Diff Checking?
I was told when I bought my LOCOST it has an LSD.
I have been re-building it for a number of months and, am about to change the oil.
According to my local motor factors, the oil type for LSD differs from the standard.
As the car is not running at the mo, I can't drive and check and I am about to change the oil and the seal what identification should be on the
diff?
thanks
As someone else once said 'LOCOST my Ar**
worX
posted on 15/3/08 at 08:51 PM |
Copied from Fesycresy post
Ford axle codes
A=3.36 B=3.77 D=3.92 F=3.842 J=4.056 K=3.31 M=3.14 N=4.29 P=3.58 J=3.62 V=3.33 Z=3.59 2=4.27 3=3.62 4=3.82 5=3.26 6=3.12 8=3.56
3,14 CW47-Pin15
3,38 CW44-Pin13
3,62 CW47-Pin13
3,92 CW51-Pin13
3,77 CW49-Pin13 6.5 inch diff
3,38 fitted to 1,6 OHC ECO 5 speed
3,38 fitted to 2,0 OHC HC
3,38 fitted to 2.3 v6 ESTATE
3,14 fitted to 1,6 OHC ECO 4 speed
3,14 fitted to 2.3 v6 SALOON
3.14 fitted to 2.3 Diesel
85GG 4006 DC --- 3.97
85GG 4006 BC --- 3.62
85GG 4006 AC --- 3.38
85GG 4006 FB --- 3.36
87BG 4006 GB --- 3.14
86GG 4006 AAA --- 3.92 LSD
V87BB 4006 BAA --- 3.62 LSD
V87BG 4006 CAA --- 3.38 LSD
85GG 4006 AAA --- 3.36 LSD
Vin plate codes for Diff ratio
Ratio Code
3.14 M
3.36 A
3.38 U
3.62 V
3.64 3
3.92 D
andrew-theasby
posted on 15/3/08 at 09:03 PM |
Think those codes are refering to sierra diffs? Im guessing yours will be an escort live axle with it being a locost?? In which case its most likely
an aftermarket lsd if it has one, not sure which, if any, english axles had an lsd as standard. It could even be an atlas which could well have an
lsd. Post a pic of the internals when you take the back off, it should be easy to tell by looking, or maybe just a few more details. If you can jack
both wheels off the ground, try turning one and if the other turns the opposite way, its open. If its stiff and turns the same way, its a lsd.
(think thats the right way round anyway) someone should be along to confirm soon
mark chandler
posted on 15/3/08 at 09:39 PM |
The LSD is just a sealed unit that bolts on the back of the crownwheel effectively, just normal hypoid oil is required, nothing special so EP80 went
in mine because thats what I had lying around
Regards Mar
andrew-theasby
posted on 15/3/08 at 10:36 PM |
I think thats correct for a viscous diff like the xr4x4, but if its an english axle, its probably a plated diff which i think maybe does need the
right oil. Could even be a quaife atb, we really need to know more info.
bjw970s
posted on 15/3/08 at 10:57 PM |
hi,
It is an English axle - the description 'of what diff' was pretty vague when I bought it hence the lack of detail - as i am taking it
out, I have got an escort manual so hopefully that will help with the ident.
Having read a number of threads, i read that the 'turning the' wheel check didn't work on early, LSD's?
itiejim
posted on 16/3/08 at 08:44 AM |
A plated Salsbury type diff needs the corrects LSD oil, otherwise it won't work (and you'll contaminate and ruin the clutch pack
plates).
I've bought it from Rimmer brothers in the past, but they might even have it in Halfords.
bjw970s
posted on 16/3/08 at 11:17 AM |
plates).
Absolutely - hence the question - will I know whether its an LSD when I take it out? (I have 2 x 1 litre bottles of oil one LSD one not on my
desk...
bjw970s
posted on 19/3/08 at 10:52 PM |
This is the Diff - any ideas on type?
[Edited on 19/3/08 by bjw970s]
omega 24 v6
posted on 20/3/08 at 12:26 PM |
it's an lsd but not one that i've seen before.
bjw970s
posted on 20/3/08 at 06:57 PM |
has anyone seen one the same?
