kango
posted on 17/3/08 at 02:12 PM |
Sierra rear width
What is the width of the Sierra diff assembly. From bearing hub face to bearing hub face?
Or can I try and explan it like this....
If I would make my own De Dion axle, what must the distance be detween the faces that the bearing carriers would be bolted to?
Is there a difference between the rear hubs with disk brake lugs and those for drum brakes?
MikeR
posted on 19/3/08 at 11:27 PM |
This has been covered before and as luck would have it i've just been reading the articles.
(not relevent to you, but if someone searches)
Escort / Capri / Cortina axles
http://www.locostbuilders.co.uk/viewthread.php?tid=23812
Sierra axles and a mention of De-dion
http://www.locostbuilders.co.uk/viewthread.php?tid=23755
