Author: Subject: On Going alternator light glow..
robbydee
posted on 23/3/08 at 10:01 PM Reply With Quote
On going problem with the alternator light faintly glowing,
HELP...
Have now changed...
alternator, battery, multiplug on alternator
robbydee
posted on 23/3/08 at 10:02 PM Reply With Quote
oh have changed the belt too., and checked the mountings..
RazMan
posted on 23/3/08 at 10:15 PM Reply With Quote
Have you checked that the alternator is charging?
Raz
Dusty
posted on 23/3/08 at 10:36 PM Reply With Quote
My bet would be the regulator. Typical symptoms are almost goes out at 1-2000 rpm but glows a little more brightly at higher revs. Battery doesn't go flat but is being overcharged. If you check with a multimeter across the terminals at 3000 rpm + you will find voltage above 15 ish.
gregs
posted on 24/3/08 at 01:13 PM Reply With Quote
could also be feedback from through your warning lamp - solved by adding a diode into the circuit...I had this on a bright six module.
