givemethebighammer
posted on 8/11/03 at 07:53 PM |
Roll bar stays
I have been trying to make some roll bar stays but am having problems cutting the joint where the stay is welded to the roll bar. Would be easy with
square tube as you could just cut a semi circle out of two opposite sides the same radius as the roll bar. Round tube not so easy. Any tips ?
image attached
[Edited on 8/11/03 by givemethebighammer]
![](/galpreviews/a65743-rollbar.JPG) ![Rescued attachment rollbar.JPG](/gallery/a65743-rollbar.JPG) Rescued attachment rollbar.JPG
Mark Allanson
posted on 8/11/03 at 09:02 PM |
Havent done it yet, but I am using 2" tube so I will use a 2" hole saw. I can see no reason why it will not work
givemethebighammer
posted on 8/11/03 at 09:08 PM |
Just found this:
http://www.ihpva.org/people/tstrike/tubemiter.exe
those clever bike building people
input the tube dimensions and it draws you a printable template ...
type 907
posted on 8/11/03 at 11:53 PM |
Hi Chaps,
The joining of two pipes to form a tee IMHO is less complicated if they are of different diameters, i.e. 2" roll bar, say 1 1/2" brace.
Then you just dish the end of the brace pipe to suit the radius of the roll bar with a grinder.
If you wish to join pipes of equal diameter you cut the end of the brace pipe at 45 deg, turn it over and cut at 45 deg again to form a 90 deg point.
The hole in the roll bar is two cuts at 45 deg half way through to form a vee. see diagram.
Personaly I think they look better with smaller braces.
The hole cutter idea would work in this case (small to large) saving shaping with the grinder.
Hope this helps.
Paul G
[Edited on 8/11/03 by type 907]
Too much is just enough
type 907
posted on 8/11/03 at 11:59 PM |
Sorry , forgot diagram.
![](/galpreviews/a65794-Lotus 021s.jpg) ![Rescued attachment Lotus 021s.jpg](/gallery/a65794-Lotus 021s.jpg) Rescued attachment Lotus 021s.jpg
Marcus
posted on 9/11/03 at 11:16 AM |
With the roll bar stays, it's called a fishmouth mitre as the shape of the .......... well you get it!
I did mine by trial and error, using the angle grinder, and was surprised by the shape I ended up with!
With a little patience it can be done.
BTW my main hoop was 2", the stays 1.75".
Alternatively use the above link and get a template.
Marcus
Marcus
Because kits are for girls!!
blueshift
posted on 9/11/03 at 03:35 PM |
I've used the tubemiter.exe program before. it's good, if it's the same one. handles different size tubes and join angles.
Alan B
posted on 9/11/03 at 04:23 PM |
I will work fine......run it slow with lube and keep it all very rigid.....
Often it is easier to have the tube double length and keep the pilot drill in the holesaw and just plunge right through making 2 fishmouths at
once.....I've done hundreds that way.....![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
givemethebighammer
posted on 9/11/03 at 10:45 PM |
Used tubemiter.exe and the old angle grinder - two perfect (well nearly) joints in about 10 mins. Shame my welding wasn't as neat. Guess
I'll just have to grind it back and sand a little before painting it ![](/images//smilies/sad.gif)
Fast Westie
posted on 10/11/03 at 04:11 PM |
I didn't quite work out with the tubemitre thing if you were cutting into the roll bar tube, cos if so, it is a no, no. The hole saw idea is the
best
The car in front is a Westfield
givemethebighammer
posted on 10/11/03 at 09:45 PM |
didn't need to cut into the roll bar.
I think it is a quirk of the program that if the size of the tube you are mitering is greater than that you are connecting to the program produces a
weird "mirror" image template. I just used one half of this to cut my joints
[Edited on 10/11/03 by givemethebighammer]
Alan B
posted on 10/11/03 at 10:06 PM |
I dont think it's a quirk....it makes sense to me....surely you wouldn't want to be fismouthing a tube that was bigger than the one it
mated with?.....you would have gaps at each side...
I think common sense says that if you have different diameter tubes that the notch will be on the smaller one?...I.E the bigger tube is the continous
one and the other joins to it....
