wjggregg
posted on 29/3/08 at 12:30 PM |
Fitting a Momo Wheel to Sierra Colum
OK - Hope someone can help here........
Problem : I curchased a MOMO 26 Leather wheel from a Caterham. The wheel is pre-drilled with a 3x50mm PCD. I don't want to drill more holes in
the wheel, and want it to fit the standard Sierra Column. Is there a suitable boss (without spending rediculous money on the weld on QR) that will fit
the sierra column to a 3x50mm PCD?
Any help appreciated!
mark chandler
posted on 29/3/08 at 12:49 PM |
Hi
I cut the ali centre out of the standard sierra wheel, then welded a plate on top which I drilled to suit.
Then to make it look neat spun it up in a lathe for a more proffesional look.
Free if you have access to the tools.
Werner Van Loock
posted on 29/3/08 at 01:55 PM |
quote: Originally posted by mark chandler
Hi
Would put some extra bolts tru the weld on plate and the original boss if I were you. Don't want to be holding the steering wheel free in a high
speed turn. Unless you're certain of your welding capacities.
http://www.clubstylus.be
jambojeef
posted on 29/3/08 at 03:14 PM |
Ok,
I have recently fitted a sparco wheel with the 3 hole pattern (guess its the same as yours)
I used a sierra 6 hole adaptor then a plate from spa design.
bit of a faff but like you I didnt want to carry on with weld on lugs and things
Geoff
