Author: Subject: Lost keys for tin top
matt_baxter
posted on 31/3/08 at 07:43 PM Reply With Quote
Hi right I am really hoping some one can help as I know that between everyone out there, there is nothing that you don’t know.
I have acquired a rover and was given a single key, unfortunately when I was starting the cylinder head I have found that I can not find the key.
Does anyone know if I can get a new key from anywhere or is that it change the locks, ignition barrel and ECU (as I am led to believe that it is matched to the key)
Any help would be appreciated and thanks in advance
Matt
Danozeman
posted on 31/3/08 at 07:53 PM Reply With Quote
What rover is it?? I think only the 75 is a chipped key??
The easiest way might be to buy a lock set from ebay or summit.
Dan
mad4x4
posted on 31/3/08 at 07:55 PM Reply With Quote
Do you need to have it runing or is it a donner?>?? if it a doner then hotwire it...
Scot's do it better in Kilts.
matt_baxter
posted on 31/3/08 at 08:02 PM Reply With Quote
I'd like to get it running for a little while before it goes into the project
And its a 1996 Rover 214
ch1ll1
posted on 31/3/08 at 08:27 PM Reply With Quote
it will have an alarm,
you can get the alarm box reprogrammed
then just go buy an ignition barrel from scrap yard,
alarm box will come back with a remote,
posted on 31/3/08 at 08:46 PM Reply With Quote
Don't know if Rover keep a record of the key numbers like Ford and Volvo do but it may be worth ringing your local Rover dealer? If they do keep a record they may want proof of ownership and I.D. Could save a load of hassle.
sparrks
posted on 31/3/08 at 08:52 PM Reply With Quote
go to the dealer they should have everything on record you will have to show log book they will give you the immo overide code and the key number you put the immo code in by the key and osf door lock
