Author: Subject: chaging cams
ricklawn
posted on 3/4/08 at 07:17 PM Reply With Quote
chaging cams
i have a 1.8 zetec from a mondeo, i have heard that i can put in 2l cams to up the power. is this right? if so is it a straight swop or do i have to chage other bits as well??
Rick
oadamo
posted on 3/4/08 at 07:25 PM Reply With Quote
you can drop in the cams and followers out of the 2L. i have a set of 136 cams in the shed that i put in a 1.8 but i had them back out when i scraped the engine so they do fit.
adam
Paul TigerB6
posted on 3/4/08 at 07:35 PM Reply With Quote
Its only worth doing if you have the lower powered version of the 1.8L as there were 2 versions
Have a look under here if you are unsure of which version you have.
ricklawn
posted on 3/4/08 at 07:36 PM Reply With Quote
does it make a big difference?
r1_pete
posted on 3/4/08 at 08:35 PM Reply With Quote
Yes its is a very noticable improvement, but if its a blacktop engine you'll need to reshim the followers.
madteg
posted on 3/4/08 at 08:49 PM Reply With Quote
Can you put 2L black top cams in a 1.8 silver top ?
posted on 4/4/08 at 08:44 AM Reply With Quote
Even if they physically fitted it wouldn't be a good idea. Cam profiles as designed to match the type of follower they are paired with, and the silver top has hydraulic followers where the black top has solid followers.
Rick
Yes, you need the larger throttle body and the appropriate ECU.
