Author: Subject: busa clutch replacement options???
markrally73
posted on 5/4/08 at 10:25 PM Reply With Quote
Well the standard clutch has finally given up and is now starting to slip!!
So whilst i got it in bits is there any mods i need to do or recommend doing whilst im in there?
replacement suzuki plates?
Uprated springs?
billet locking centre ring?
http://www.hayabusacentral.co.uk/shop/product.asp?idproduct=109&source=thumb
Any advice welcome
Ps do i need to remove the whole cover or just the 3 bolts in the centre of the cover? i havnt got the manual out yet !!
Any advice on what oil to use as i have heard some are better with promoting clutch friction then others?
cheers
Mark
motorcycle_mayhem
posted on 6/4/08 at 07:46 AM Reply With Quote
After several plate burn-outs, slips, etc. I went for a kevlar set (from PDQ), along with uprated springs. These didn't burn out, despite a season's sprinting abuse, but grabbed violently - really violently - not that I cared.
I kept the basket, centre etc., as standard, no problems. The end ally plate on the clutch basket took a hammering (but was cheapish to replace periodically).
Jason Fletcher
posted on 6/4/08 at 09:26 AM Reply With Quote
You will need to remove the whole clutch cover not just the one held on by the three bolts. You could also do with fitting a new gasket too.
Take a look at Brock performance products. They are in the States but with the weak Dollar it makes good sense to buy from there.
I recently bought the one piece centre from them. The one I got is in aircraft grade aly and is supurb. It comes with spacers to stiffen the springs up without replacement. Really good company to deal with too!
Jason
