hobbsy
posted on 9/4/08 at 01:18 PM |
What are these washers called (banjo bolt off fuel tank)?
This year over Xmas my Fury developed a slight fuel leak again. Seemed to be coming from this banjo bolt which bolts up to a square section from the
bottom of the tank (acts slightly like a tank baffle so the pump always gets fuel).
Anyway last year I just gingerly nipped it up as tight as I dared (worried it might shear plus this bottom square protrusion of the tank was flexing
as I gave it some welly).
Tried the same just now and left it over night but its still leaking.
In the photo you can see the banjo - I thought it might have used copper washers but they are steel with a rubber insert.
One has the tiniest of nicks in it but might have happened when I pulled it over the threads.
Should I replace like for like or go for copper.
Also what are these called and whats the best place to buy them from?
Guess Think Auto will do them but might be expensive
They are approx 24mm OD and 14.5mm ID.
Any other ideas how I could improve this?
The blue ally bolt is approx 16mm OD.
![](/galpreviews/a723207-fuel tank fitting.jpg) ![Rescued attachment fuel tank fitting.jpg](/gallery/a723207-fuel tank fitting.jpg) Rescued attachment fuel tank fitting.jpg
mike smith1
posted on 9/4/08 at 01:27 PM |
They are call doughty seals
HTH Mike
hobbsy
posted on 9/4/08 at 01:32 PM |
Thanks for that Mike.
Seems to also be spelt dowty seals, I guess I'll try replacing them first as the cold might make them shrink and the nick looks worse in the
photo.
Cheap enough on fleaBay:
http://cgi.ebay.co.uk/3-4-Hydraulic-Dowty-Bonded-Seal-Pack-of-10_W0QQitemZ200212998070
richardlee237
posted on 9/4/08 at 01:41 PM |
They are Dowty seals, but they are really intended for 200 bar systems. Hence the heavy steel ring and small rubber seal.
IMHO for sealing a relatively low pressure fuel system you would be better off with copper sealing rings as they will conform to the irregularities of
the banjo better.
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
Danozeman
posted on 9/4/08 at 01:44 PM |
Id just put copper washers on there. Much cheaper than dowty washers and probably more suited to your need.
Dan
short track 123
posted on 9/4/08 at 02:34 PM |
If you are in Northampton I would give this place a try they will have the right washer to go with the banjo bolt you have. May not be the cheapest
but is it worth taking the risk with fuel system parts ? ( and with the cost of petrol you don't want to wast it )
Earls
Regards
Jason
clanger
posted on 9/4/08 at 03:37 PM |
Also sometimes known as a bonded seal
hobbsy
posted on 9/4/08 at 03:50 PM |
I was considering swapping to copper once I saw they were steel, not so much for the irregularities of the banjo but the mating surface on the tank
face (which may have suffered further distortion with me trying to compress a steel washer!).
Just need to find some correct diam copper washers then... back to eeeeeeeeBay
locogeoff
posted on 9/4/08 at 04:11 PM |
I usually buy them from my local motorcycle shop, since I've got a few things that all seem to have the same sized washers I've been
meaning to buy a box of them but so far have not found anyone willing to sell such a commodity
omega 24 v6
posted on 9/4/08 at 04:24 PM |
problem could be that you are not using petrol proof ones??? You need a seal with viton inserts IIRC
adithorp
posted on 9/4/08 at 08:28 PM |
Is it the plastic tank from "The kit car workshop"? If so they'er prone to leaking from the banjo's. Its because the moulded
in captive moves in the plastic and they leak around between the nut and tank. Mine did it (just started from the fuel return as well), Rob
Colinridges did it, several others have reported it. The give away is slight play (less than a degree) either way, in the banjo when you put a spanner
on it even though its tight.
Because of where its from it doesn't seal under the washer. Answer is a big washer (with fuel proof sealant) under the banjo and seal washer.
The other answer is an ally' tank!
On another point; I had fuel supply problems untill I drilled another pair of holes through the banjo bolt at 90' to the existing ones. Made a
hell of a difference.
adrian
hobbsy
posted on 9/4/08 at 08:54 PM |
Hmm I suppose it could be plastic the way it flexes - its black and as I've always been on my back with fuel dripping on me I've not hung
around longer than I need to.
Also I didn't build the car myself (bought it off someone who paid for it to be factory built).
What would you suggest to use as a fuel proof sealant?
Is instant gasket or similar fuel proof (CBA to open garage to read the packet!).
Hmm I might drill those 2 extra holes even though I don't *think* I have a problem.
How did you spot yours - fuel pressure gauge or just by how it drove?
I'll have a look on Rob Collingridges website for some photos to see if it looks similar to mine.
Its weird how mine only seems to leak when its been sat for a while over the winter months.
Dead obvious as I open the garage door and get hit by fumes.
I put my plastic oil catch tray under it to see how quickly it was coming out. This was a mistake as when I next looked in it had completely melted
it to the floor - doh!
hobbsy
posted on 9/4/08 at 09:08 PM |
Just had a look on the Fisher build site, this is what my tank looks like to maybe it is plastic after all (doh!):
The banjo is on the side facing the diff.
adithorp
posted on 9/4/08 at 09:25 PM |
Yes, thats the one. It's a design fault; The nut is molded into the skin of the tank with the nut flush with the outer surface, as opposed to
inside the skin where it would tighten down trapping the skin forming a seal.
I used some stuff that I had at work; brilliant stuff but no longer available, sadly. Red Hermetite should do. Silicone won't do and PU is
debateable.
I've looked through my photos but haven't got one showing the repair.
adrian
Dingz
posted on 11/4/08 at 02:34 PM |
Hobbsy, If you u2u me with your address I can send a pair in viton of what I think are the same size.
hobbsy
posted on 11/4/08 at 04:17 PM |
Dingz - thank you for your kind offer but I just ordered some and he says they are ok for petrol.
Plus looking at the last few posts it seems it might not have been the seals that were to blame but the design of the tank / captive nut.
Dingz
posted on 11/4/08 at 06:24 PM |
Thats ok, blue hylomar is good for sealing against petrol btw.
