Author: Subject: Wanted Dial Gauge
clockwork
posted on 11/4/08 at 03:21 PM Reply With Quote
Wanted Dial Gauge
For checking disc run out, so with an arm.
Can only find 'non arm' versions.
Any ideas where I can get one?
If the arm is removable that would be a bonus...
Ta
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
MikeCapon
posted on 11/4/08 at 04:15 PM Reply With Quote
If it's one like this you're after
Image deleted by owner
It's a lever dial gauge. Try here
Linky
www.shock-factory.co.uk
MikeR
posted on 11/4/08 at 05:38 PM Reply With Quote
have you checked out screwfix?
paulf
posted on 11/4/08 at 07:01 PM Reply With Quote
That type is ok for small runnouts such as when setting machine tools but a plunger type with 10 or 12 mm travel is more use for working on engines etc.
Theres always some on Ebay or as mentioned screwfix do one for£16.99 cat no 58566-90
Paul.
Linky
clockwork
posted on 11/4/08 at 07:02 PM Reply With Quote
I have been able to find dial gauges, e.g.
http://www.screwfix.com/search.do;jsessionid=P5S4SFO0LNORQCSTHZPCFFA?_dyncharset=UTF-8&fh_search=dial+gauge
but I am ideally after one with a (detachable) arm.
I have seen them in the past, I think in a back street auto shop, but didn't have a use for one. Now I want one, I can't find one.
907
posted on 11/4/08 at 07:32 PM Reply With Quote
There are dial gauges on eBay. Search for dial test indicator.
360039712904 looks a reasonable price.
I use mine with a magnetic mount.
hth
Paul G
paulf
posted on 11/4/08 at 07:41 PM Reply With Quote
For what you are doing that will be ok mounted on a suitable mag stand, the lever arm type only have about 30 thou total travel and are not as easy to use for general work, they are more for machine tool set up.
Paul.
