ricklawn
posted on 26/4/08 at 12:29 PM |
Bike carbs
Hi guys
I have bought a set of gsxr 750 carbs for my fury. what is the best way to clean them ie strip and dunk in soapy water or strip and use small brush
and carb cleaner? is there anything i should be aware off before i start?
thanks
Rick
[img]http://[/img]
posted on 26/4/08 at 12:32 PM |
Carb cleaner and compressed air if you have a compressor...
DO NOT do as I did and soak them in thinners... they were in the dustbin soon after as the thinners wrecked the insides of the carbs![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
COREdevelopments
posted on 26/4/08 at 02:55 PM |
wouldnt use soapy water either! carb cleaner is the good option. or diesel or petrol if you wanna keep it locost
rob
posted on 26/4/08 at 07:56 PM |
toothbrush and petrol/parafiin.
posted on 26/4/08 at 08:15 PM |
DarrenW
posted on 26/4/08 at 08:29 PM |
I used some petrol / diesel mix a mate had left over from a tank drain. After external surfaces were clean i opened each one up in turn and cleaned
with carb cleaner.
I found them easy to do. There is surprisingly little to bike carbs.
