Author: Subject: pinouts for a zx9 rectifier
larrythelathe
posted on 29/4/08 at 08:11 AM Reply With Quote
will i find switched 12volts anyplace on the rectifier i am going to put a fan on it.
Pdlewis
posted on 29/4/08 at 08:19 AM Reply With Quote
Could you not run a spur off the rad fan then you will only be colling it when you know the engine is already warm?
larrythelathe
posted on 29/4/08 at 08:22 AM Reply With Quote
nope
its getting hot in the position its in i need it to run straight away. Its only a little PC fan.
posted on 29/4/08 at 08:51 AM Reply With Quote
be vcareful here = i have a feeling that the regulator/rectifier are connected to the battery permanently. they will charge the battery when engine is running but will be live wehn engine is not running.
i suggest you tap into the swtiched ignition live.
mackei23b
posted on 29/4/08 at 09:23 AM Reply With Quote
Just had a look at the Kawaski wiring. If you are still using that then brown on the pin out from the regulator should be switched live from the ignition (unfused).
So if you use that, put a small in-line fuse in for the fan.
Ian
larrythelathe
posted on 29/4/08 at 09:24 AM Reply With Quote
STAR
thanks
thats what i was after many thanks i love this forum.
