ryland06
posted on 1/5/08 at 07:20 PM |
changin fuel injection to carbs???
i just bought a sierra as a doner car for my mk indy build and was wonderin is it possible to change my 2lt pinto from fuel injection over to
carbs??
[Edited on 1/5/08 by ryland06]
theconrodkid
posted on 1/5/08 at 07:23 PM |
put a carb inlet manifold and carb on,get a fuel pump and push rod,job done.
the bottom of the inlet ports are a bit close to the outside of the gasket but it never caused me a problem
who cares who wins
pass the pork pies
nib1980
posted on 1/5/08 at 07:37 PM |
What he said, no hassle at all, infact probably easier for your build in the long run
mookaloid
posted on 1/5/08 at 07:41 PM |
I would suggest Bike carbs for improved performance
Dragon-Performance-Eu
posted on 1/5/08 at 07:43 PM |
Erm not wanting to pi** in anyone chips and all but.....
you might find that a manifold for a set of carb's may or may not fit on to the injection head as the inlet manifold's for carb and
injection are different, also the injection head has extra pockets cut into it for the injectors fuel spray from the manifold.
[Edited on 1-5-08 by Dragon-Performance-Eu]
theconrodkid
posted on 1/5/08 at 07:48 PM |
thats why i mentioned the bit about the gasket,never had a problem with that and get your own chips if you want to do that sort of thing
who cares who wins
pass the pork pies
posted on 1/5/08 at 07:51 PM |
agreed, just seen more than a few having "almost untraceable" air leaks after having this conversion done (I think it depends on the brand
of gasket you use)
John.Taylor
posted on 1/5/08 at 08:09 PM |
I'm on the look out for a cheap Sierra Pinto EFI intake manifold (complete) to butcher up if your's is surplus to requirements.
Paul TigerB6
posted on 1/5/08 at 08:31 PM |
Arent the injection Pinto's all those with the sought after 205 block's?? I just fitted a 205 Pinto with twin Weber's but as above
i'd definately go for the bike carbs with a suitable manifold.
Ryland06, have a look on the side of the block on the exhaust manifold side - there should be a number cast into the block - 16, 20, 205 etc.
mat.price
posted on 1/5/08 at 08:41 PM |
i had a air leak so i got my mate to make a plate to cove the holes for me
i put an injection gasket on the plate then the carb gasket with the bike carbs works a treat
posted on 1/5/08 at 09:20 PM |
that would cure it right enough, i just didnt want the o/p thinking it was all plain sailing when issues can occur
Dingz
posted on 1/5/08 at 11:12 PM |
Use a cheap pattern carb gasket and it is usually ok. the real ford gaskets are a bit thin in the top area.
mat.price
posted on 2/5/08 at 07:36 AM |
i got a gasket form burton power that was quit strong and thick that might do the job for you
https://www.burtonpower.com/product_main.aspx?prodLanding.aspx?CCode=PC090
