Author: Subject: Fireblade Tacho Pulses
charlierevell
posted on 10/5/08 at 09:37 AM Reply With Quote
Does anyone know hows many pulses a 954 - 03 blade produces per revolution??
Tango orange is an 'IN' colour!!
tks
posted on 10/5/08 at 02:18 PM Reply With Quote
just measure it with a multimeter wich has an HZ funcion..
put the engine on tickover.
and calculate the following scenarios..
- 1 pulse per cilinder 1
- 1 pulse per spark
- 1 pulse per revolution...
should be easy...
TKs
mark chandler
posted on 10/5/08 at 05:47 PM Reply With Quote
Two
charlierevell
posted on 12/5/08 at 08:16 AM Reply With Quote
Did a bit of trial and error and found that its two.... cheers to the above for confirming tho.
Was just to set up a shift light, it seemed slightly out but must be my tacho out.
