madmandegge
posted on 12/5/08 at 12:04 PM |
replacing drum bleed nipple
Hi all,
Went to bleed the brakes on my recently purchased MK, one of the rear nipples is non-functional. I can't rotate it, have even tried locked mole
grips and they just "eat" into the nipple, it won't shift.
Is it possible to replace them? Sorry for the noobie question
TIA! Simon
cjtheman
posted on 12/5/08 at 12:20 PM |
yes they can be replaced if you cant get it out by unthreading it you could always replace the wheel cylinder not to expensive i have spare escort one
and cortina ones if that would help
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
mookaloid
posted on 12/5/08 at 12:35 PM |
I generally find it's not worth messing about with that - if the nipple is that far gone then the rest of the wheel cylinder is probably not far
off being sha**ed.
Just buy a new one and fit it they aren't a lot of money and it's easy enough to do .
Mark
Coose
posted on 12/5/08 at 12:44 PM |
And don't forget to copper grease the threads on the new bleed nipple!
Spin 'er off Well...
mookaloid
posted on 12/5/08 at 01:09 PM |
Good point
RichardK
posted on 12/5/08 at 01:55 PM |
b0ll%cks, guess what I've forgot to do
Rich
Gallery updated 11/01/2011
posted on 12/5/08 at 02:34 PM |
Just bleed through the pipe --
Hold pedal down and close the nipple at the end of each stroke.
tks
posted on 12/5/08 at 06:36 PM |
copper grease?? with brake fluid???
i would replace both sides then since the cilinders then are identical...
Tks
IndyJohn
posted on 14/5/08 at 01:56 PM |
Hi
I had that problem so I replaced the other 3 and then gave the new owner 2 spare nipples for the one i could not get out
