JEPY
posted on 17/5/08 at 08:33 PM |
Anyone fitted a Focus ST 2.5?
Has anyone fitted a focus ST 2.5 turbo engine to their locost/se7en?
If so, does it fit a standard bell housing pattern?
What ECU can be used on a 5 cylinder?
How much clearance would there be around the engine/turbo?
Seems like a good way to get cheap power if it would fit
James
posted on 17/5/08 at 08:41 PM |
Thought about it myself but with the current Ford line up of engines being married to Volvo nor sure about suitability.
All I know is the current Mondeo/S-Max 5 cylinder is a Volvo unit.
Would be a super choice in a 7 for sure![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
neilj37
posted on 17/5/08 at 08:43 PM |
I was wondering if you could use a 306 GTi-6 engine in a seven. Anybody know if that has been tried?
Volvorsport
posted on 17/5/08 at 08:51 PM |
im not going to reply here
www.dbsmotorsport.co.uk
getting dirty under a bus
JEPY
posted on 17/5/08 at 09:53 PM |
Hmm, if it's a Volvo unit, wonder if the 340/360 or 740/760 bell housing and box would fit?
Volvorsport
posted on 17/5/08 at 10:16 PM |
nope ,
960 straight six with manual , rare as .
damn ive posted .
dhutch
posted on 17/5/08 at 10:17 PM |
I think the issue with that (having seen the same quesion raised elsewhere) is the lack of any suitable rwd peugote gearbox.
- If it has been done, it would proberbly involve some work!
Daniel
phelpsa
posted on 17/5/08 at 10:27 PM |
Daniel
Peugeot engines are very banked.
Could be done using the gearbox from a peugeot diesel engined Sherpa but not sure what that box would take.
Plus those pug engines arent the best engines out there and dont come cheap, aren't really worth it tbh.
posted on 17/5/08 at 10:32 PM |
Peugeot Mi16 engine has been done, but whilst a nice light engine with plenty of power, if suffers badly from oil surge problems, so dry sump is a
very good idea.
Allegedly the gearbox from a Sherpa diesel fits, but I suspect the ratios would be appalling. Bellhousings for Ford box used to be available but
manufacturer ceased a long time back.
matt_claydon
posted on 18/5/08 at 05:23 AM |
The Focus ST is the same as the Volvo T5 engine. I'm in the process of putting one in my MK using a BMW gearbox and will post details when done.
There's past posts on here with some info and lots on Turbobricks forum.
I'm sure it would be much cheaper to source as a Volvo unit that as a Focus ST unit.
Danozeman
posted on 18/5/08 at 03:52 PM |
I saw a westy at stoneleigh last year with one in. Cant post apiccie cos itson my old hard drive which wont work in this pc.
Dan
JEPY
posted on 18/5/08 at 08:43 PM |
Excellent news Matt, look forward to seeing the result.
Will keep building mine as a 2 litre zetec, but it's worth keeping in mind for an future upgrade
Cheers chaps
andyps
posted on 21/5/08 at 12:25 PM |
Rather than the Ford, why not the Fiat Coupe 20VT engine. It is another 5 cylinder but produces almost the same power as the ST whilst being capable
of 300bhp easily and cheaply, and quite a lot more if you are prepared to spend some money. Probably a lot cheaper than a Ford engine, now available
for not much over £500 for a good one.
posted on 21/5/08 at 05:33 PM |
quote: Originally posted by andyps
Probably a lot cheaper than a Ford engine, now available for not much over £500 for a good one.
Where from? IME genuinely good ones (and there aren't many left) usually fetch upwards of £700.
It's a sweet sounding engine with plenty of power, but they are quite heavy. Is there a suitable RWD box that would bolt onto it?
