Author: Subject: Spinning my front wheels whilst up on axle stands...
The Great Fandango
posted on 19/5/08 at 08:23 PM Reply With Quote
I've just fitted my new Wilwood Powerlite calipers and Rally Design discs but noticed once I'd put the wheels back on and tightened them up, the front left disc grates against the pads for part of the rotation.
I've not bled the system or driven the car yet but this takes me back to childhood days when I had a buckled wheel on my bike.
Is this normal?
Kyle, Leeds
He Who Dies With The Most Toys Dies The Happiest
clockwork
posted on 19/5/08 at 08:26 PM Reply With Quote
Grit on the back of the disk so it doesn't sit flush on the hub?
Slight high spot on the disks?
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
mookaloid
posted on 19/5/08 at 08:31 PM Reply With Quote
It will probably be ok when they are bedded in
Bluemoon
posted on 19/5/08 at 09:17 PM Reply With Quote
You didn't paint the hub/disk mating surface? A lot seem to but this could leed to the disk/wheel not runing true etc etc..
Dan
rick q
posted on 19/5/08 at 11:27 PM Reply With Quote
When I did mine a little while ago, that happened. I pulled it apart, rotated the disk one bolt further round on the hub and so on till I found the best spot.
There's a maximum runout allowable - you'll probably find it on the Willwood site - but if you don't sort it, they'll judder like mad.
posted on 20/5/08 at 10:20 AM Reply With Quote
Some run out is normal but try as rick q suggests if it still dosen't seem right send them back in a package clearly marked snake oil.
