<<  1    2  >>
Author: Subject: Moving along nicely...front brakes
Alan B
posted on 22/5/08 at 01:14 PM Reply With Quote
My laser cut caliper brackets came in so I could assemble the front brakes.
The Great Fandango
posted on 22/5/08 at 01:39 PM Reply With Quote
That's all looking rather blimin' nice is you don't mind me saying...
He Who Dies With The Most Toys Dies The Happiest
speedyxjs
posted on 22/5/08 at 03:46 PM Reply With Quote
Very nice
How do you progress so quickly? Do you not work for a living
posted on 22/5/08 at 04:15 PM Reply With Quote
Nice
Hopefully one of these days someone will start manafacturing laser-cutting machines for the home market. After all a 2D version is only a plotter with a wacking grate laser attached to it instead of a pen!!!
Alan B
posted on 22/5/08 at 05:06 PM Reply With Quote
Fandango...thanks
Speedy...yes I do work, sadly, but most of my recent work has been in my shop so it's easy to sneak the odd hour in..
Ben...yep, pretty much..plasma machines are readily available (I have one) but the laser part is pretty expensive.
Chris.....nope not going 4WD, but could if I wanted. The hub is completely self-contained and does not rely on the CV bolted through to hold it together, therefore it can be used as a non-driven hub in this application meaning I can use the same one all round.
[Edited on 22/5/08 by Alan B]
skydivepaul
posted on 23/5/08 at 02:31 AM Reply With Quote
coming togethor very nicely Alan. looking forward to the day it turns a wheel
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Alan B
posted on 23/5/08 at 11:03 AM Reply With Quote
Oh I can turn the wheels now Paul....
But, yeah, I know what you mean..
sgraber
posted on 26/5/08 at 04:44 AM Reply With Quote
Looking so great Alan!
WRT to the GM hub. I have a bit of news for you. recently I was playing around with that same hub and trying to press a piece of 1" x .085 wall DOM through it. It's a very close fit and I thought it would just go through, but as I was persuading the tube to mate with the splines, the entire hub came apart! Pressed right out in deed. So I don't understand your statement about not needing the cv bolted on it. It definitely needs something to hold it together.
My plan was to use that piece of tube with a machined groove and a circlip on each side. Would be very light.
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
Alan B
posted on 26/5/08 at 01:29 PM Reply With Quote
Steve, now I'm puzzled...
As far as I'm aware the hubs that need a CV through to hold them together basically are in two pieces internally, whereas the Chevy Cav hub unit is one piece so theoretically having the CV in or out should make no difference to the hubs integrity. In other words between the shoulder of the CV and the nut is only one component, therefore it is holding nothing together.
I am not doubting your observations, that's why I'm puzzled. I wonder if we have different hubs or different versions?
I will be checking it out for sure today Steve, and appreciate the heads up.
If you have a picture or sketch of how it came apart that would be really useful.
Alan
[Edited on 26/5/08 by Alan B]
Alan B
posted on 26/5/08 at 01:51 PM Reply With Quote
Further to my previous post.
I'm convinced that if the CV does effectively clamp two parts together then a CV substitute is required, and as Steve says should be simple to do.
However if it is only one piece (and to be honest I'm leaning away from this) then I don't see what the CV can do to hold it together.
More later........
Alan B
posted on 26/5/08 at 02:21 PM Reply With Quote
Steve is right....I am wrong.......as I said peviously I never doubted Steve's observations.
The hub unit DOES need a CV dummy or equivalent to hold it together.
I actually have two different hub brands of slightly different design. One is definitely in two pieces (referring to internal rotating parts) the other clamps to the bearing directly so effectively is in two parts also.
So.......I know today's project..
Again, thanks Steve for finding this out.
sgraber
posted on 26/5/08 at 03:11 PM Reply With Quote
Hey! This is exactly what this forum is for!
I thought too that the hub would be fine without a center bolt, but then noticed a hairline split inside the splined area. Then when I started to tap that 1" od tube through the center and it started to come apart I knew that it would need to be clamped somehow together.
What do you think of my tube/circlip idea? The tube is so close to fitting btw. just a bit of emery cloth on a lathe might make it go through.
Steve Graber
Alan B
posted on 26/5/08 at 03:17 PM Reply With Quote
Steve, the circlip idea would hold it together, but would not stop it loosening up in the first place....that's why I'm working on a clamping sleeve.
I should have an idea to post very soon.
Alan
Alan B
posted on 26/5/08 at 03:23 PM Reply With Quote
This is what i'm going to do...
It's basically a flanged sleeve and thick washer held together with a 3/4-16 cap screw
sgraber
posted on 26/5/08 at 03:42 PM Reply With Quote
How about getting a set of the cv ends, machining down the inside section to fit within your spindle, then center-boring the remaining bolt to remove weight?
Steve Graber
Alan B
posted on 26/5/08 at 05:16 PM Reply With Quote
Could do that except I haven't got old CVs and just have made the part since last posting...
The sleeve and bolt only weigh a few ounces, although putting a 1/2" hole through the bolt would be easy enough.
Syd Bridge
posted on 26/5/08 at 06:15 PM Reply With Quote
That's not far off what they do in the MGF, to hold the front together. Also used many years previous by Frogeye Cars here on the island, to use Metro hubs on the front. They just machined the CV female section off, leaving the flat disc.
A very nice option Alan, and keeps things a bit simpler and lighter.
Syd.
Alan B
posted on 11/6/08 at 08:21 PM Reply With Quote
These are the parts that allow the hub to be used without a CV....
Seems to work quite well, and not too heavy.
sgraber
posted on 11/6/08 at 09:46 PM Reply With Quote
that dog's got some big-uns!
Very nice I mean.
Will you be making a run of these? I am interested.
S.
[Edited on 6/11/08 by sgraber]
Alan B
posted on 11/6/08 at 10:09 PM Reply With Quote
Steve,
Thanks,
How many do you want?....if we can order enough sets I should be able to get a good price.
Alan
sgraber
posted on 11/6/08 at 10:47 PM Reply With Quote
I will contact you via email as soon as I am out of bed and back at the desktop PC. I do have some other things I need to purchase from you.
Steve Graber
tadltd
posted on 18/6/08 at 08:43 PM Reply With Quote
Tuppence worth:
We used the splined rear hub from the E36 3-series all round on the LMP. The front hub clamping issue was obvious from the outset and we initially devised something similar to Alan's solution.
It didn't work. The splines in the hub are - correct me if I'm wrong - case hardened, which means they're going to be harder than anything else you put against them (unless that too has been treated in the same way). This means they will soon eat into any shaft that isn't splined because it is only engaging with the 'teeth' of the hub and movement will soon result, with failure not long after that.
When you consider the lateral and vertical forces trying to pull the shaft out, you'll soon understand why this happens.
So, we reverted to machined CV ends (which can be sourced at a reasonable price). They were cut on a lathe exactly as Syd describes, with a flat on the inside, and drilled about 3/4 of the way through to reduce weight.
Never had any trouble after that.
So before you go into production and start selling bits, Alan, I'd see how those bits perform under proper test conditions...
I worry about you lot.
Sometimes.
[Edited on 18/6/08 by tadltd]
Best Regards,
Steve.
www.turnerautosport.com
Alan B
posted on 19/6/08 at 12:32 AM Reply With Quote
Concern and observations duly noted.
I will make sure that they are thoroughly inspected afer hard testing.
Thanks for the heads up.
Alan
Doug68
posted on 19/6/08 at 01:02 AM Reply With Quote
Hi Alan,
Aren't there front hubs you can get that don't need the mod?
I'm using C5 Corvette stuff all round & they have this type of hub on all 4 corners, so obviously its just a straight bolt on job. Pontiac Solstice perhaps? (A complete wild guess).
I doubt the C5 parts would work directly for you though as they've an odd offset and bolt centers ( 4.75" ) and not 120mm which is a pain in the bum.
[Edited on 19/6/08 by Doug68]
Doug. 1TG
Sports Car Builders WA
Alan B
posted on 19/6/08 at 01:39 AM Reply With Quote
Hi Doug,
Yes there are specific non-driven hubs that exist in the correct PCD and bolt size and number (in fact they are the corresponding rear hubs, in this originally FWD application) so I do have those to fall back on even though some mods would be needed..I guess it's case of what works safely for the least hassle and money....I'm pretty confident I can make work what I've done so far.
Alan
Originally posted by Doug68
Hi Alan,
<<  1    2  >>
