<<  1    2  >>
Author: Subject: SVA on Tuesday, photos to check for silly mistakes
Steve Lovelock
posted on 24/5/08 at 09:52 AM Reply With Quote
Hello,
With the weekend set aside for car action in advance of SVA test on Tuesday I want to check to see if I had missed anything obvious. I will create a photo archive called SVA but please have a look at these to see if I have missed anything obvious, cheers. Rescued attachment DSC02106a.JPG
Steve Lovelock
posted on 24/5/08 at 09:53 AM Reply With Quote
Steve Lovelock
posted on 24/5/08 at 09:54 AM Reply With Quote
Steve Lovelock
posted on 24/5/08 at 09:56 AM Reply With Quote
Steve Lovelock
posted on 24/5/08 at 09:57 AM Reply With Quote
Hammerhead
posted on 24/5/08 at 10:02 AM Reply With Quote
is the leading edge of your cycle wings in front of the furthest forward part of your alloy rims?
Looks good by the way.
joneh
posted on 24/5/08 at 10:03 AM Reply With Quote
I don't know anything about the SVA but I know thats a nice looking car!
smart51
posted on 24/5/08 at 10:07 AM Reply With Quote
A very nice looking car.
Does the trim on the "door" apperture have a 2.5mm radius?
Is the rear fog light vertical?
Is the square plate under the headlight contactable with the dreaded sphere or correctly radiused?
Are the front indicators within 400mm of the edge of the car.
Otherwise, very tidy.
001Ben
posted on 24/5/08 at 10:15 AM Reply With Quote
I will second joneh and say that is one nice motor.
rayward
posted on 24/5/08 at 10:26 AM Reply With Quote
you may need some protection on the adjuster at the bottom of the spring on your front shocker
Ray
nitram38
posted on 24/5/08 at 10:32 AM Reply With Quote
Very nice looking car!
Those are the wheels I have got for the MotaLeira
Johneturbo
posted on 24/5/08 at 10:54 AM Reply With Quote
Very nice looking car. looks well put together, i've got my SVA the following tuesday at edmonton, i take it your going to edmonton? if you are could you put a word in for me
good luck with it
posted on 24/5/08 at 11:46 AM Reply With Quote
Are the mirrors high enough? As already suggested some protection for the front spring adjustors . Some radio controlled car tyres would fit OK. Did you get your engine running properly? Break a leg.
[Edited on 24/5/08 by rusty nuts]
omega 24 v6
posted on 24/5/08 at 11:54 AM Reply With Quote
Very nice looking motor but where is the fog light??? If as I suspect it's on the offside then you've got a problem because there has to be a minimum seperation of 100mm from a brake light sorry to pee on your chips and that but better now than later fail. it'll be an easy sort though.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 24/5/08 at 12:00 PM Reply With Quote
hey hey, thats what i did!!
EDIT to say: it passed by the way!
[Edited on 24/5/08 by iscmatt]
chris_smith
posted on 24/5/08 at 12:14 PM Reply With Quote
is there a reflector in the rear light pods or do you need one?
superb looking car well done atb
chris
Steve Lovelock
posted on 24/5/08 at 02:08 PM Reply With Quote
Thanks for the +ve comments.
I think I have most of the things highlighted covered or will do so. The one that has got me is the 100mm separation of the fog & brake light, can anybody else confirm that?
The test centre is Edmonton, they were very reasonable when I took my last kit 4 years ago. However, the engine isn't running at the moment so I have a race against time on that one.
tks
posted on 24/5/08 at 02:26 PM Reply With Quote
I have got the same thing..
i used fiat coupe lights and they have them integrated together with the direction lights... they are E-Marked...(fiat / valeo is the brand)
So basicly i cant move the fog without moveing the direction light
What would they do/say???
Tks
Paul (Notts)
posted on 24/5/08 at 05:22 PM Reply With Quote
SVA manual states 100mm sep from a stop light to fog light. - If they fail you on it all you need to do for the re test is disconnect the one you have and fit a bracket with one on in the correct place.
the underside of the front light mounting will need trim all the way round it.
Good luck..
Paul
Macbeast
posted on 24/5/08 at 07:31 PM Reply With Quote
Rear reflectors?
Looks nice Steve. Where are you taking it for SVA as I'm in Wood Green and will probably have to tale it there too.
Edit to say -
Edmonton - right
[Edited on 24/5/08 by Macbeast]
tks
posted on 24/5/08 at 09:20 PM Reply With Quote
Good luck..
Paul
yupsz but mine will be looking square and his aren't (from those pics....)
so the fog is deff gonna be an issue for him.
i hope i can get away with it...
Tks
Steve Lovelock
posted on 24/5/08 at 11:01 PM Reply With Quote
I have an old fog light that I can mount on the back of the car for the test so it wont be an issue. I didn't know about it though so I am very pleased I put the post on.
NeilP
posted on 25/5/08 at 06:54 PM Reply With Quote
Looks brill, Steve - Very best of luck, mate...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Steve Lovelock
posted on 27/5/08 at 12:44 PM Reply With Quote
Well it passed and I am delighted. Just had to cover a wire with trunking and everything sailed through. I can recommend Edmonton as a centre, the chap was really trying to make sure everything was acceptable.
Off to the DVLA centre now.
Brilliant
mistergrumpy
posted on 27/5/08 at 12:54 PM Reply With Quote
Well done mate. Thumbs up for another good build
<<  1    2  >>
