Author: Subject: Ignition barrel pinout.
tks
posted on 24/5/08 at 02:10 PM Reply With Quote
Anyone knows the pin out of the ignition barrel???
i need to know the pins wich connect with each other as soon as the key is placed and wich from then don't disconnect anymore!!
Tks
big_wasa
posted on 24/5/08 at 02:23 PM Reply With Quote
none of the pins conect to earth.
Main live in , switched live out , acc , start
tks
posted on 24/5/08 at 02:35 PM Reply With Quote
thanxs...
but i said the 2 pins wich connect with each other
will print your diagram...
Tks
big_wasa
posted on 24/5/08 at 02:43 PM Reply With Quote
sorry must of speed read it
position 1 live to acc
poition 2 live to acc and swtched live (run)
position 3 live to switced live (run) and start but not acc
[Edited on 24/5/08 by big_wasa]
