Author: Subject: best/cheapest ecu for a v6
DIY Si
posted on 25/5/08 at 02:57 PM Reply With Quote
Right then, all this ecu stuff is a bit foreign to me as I grew up on a diet of SU's and dizzys. Can someone tell me what sensible options I have when it comes to fuelling and sparking a V6? Will megasquirt handle this without much bother? I know there's a ford 6 cylinder spark thingy, the name of which has escaped me at the moment, so I know that bit can be done. Ideally I'm after something that is fairly easy to sort out, so megasquirt shouldn't be a problem to figure out and get set up. What other options are there? I don't necessarily need a full plug and play install, but I don't want to be building the ecu from scratch either.
Oh, the engine will be an Alfa V6 running on triumph throttle bodies, so nothing fiddly like Vtec switching is required. Although the future potential to run a supercharger without too much modification would be a distinct advantage.
PS, a budget of 10p would be preferred!
[Edited on 25/5/08 by DIY Si]
clairetoo
posted on 25/5/08 at 03:01 PM Reply With Quote
I picked megasquirt and an Edis to run my V6 - has to be the cheapest way of doing it as far as I can tell .
I bought mine fully built as electronics really isnt my `thing`
Its cuz I is blond , innit
Claire xx
Will weld for food......
DIY Si
posted on 25/5/08 at 03:05 PM Reply With Quote
EDIS, that's the name of the spark thingy! Right, off to the Bay of E.
Claire, where did you get yours from? And if you don't mind me asking, how much was it?
DIY Si
posted on 25/5/08 at 03:12 PM Reply With Quote
Oh, just noticed that some of the Alfa V6's run coil on plug. Does this complicate things at all? Or does it make things a bit simpler?
clairetoo
posted on 25/5/08 at 03:16 PM Reply With Quote
I originally bought one from Mtech (bunch of total cowboys - avoid like the plague) , Bill Shurvington supplied the one I`m actually using , along with an Lc1 wideband lambda setup .
Not too sure about the cost as I still need to sort that out .......
Claire xx
clairetoo
posted on 25/5/08 at 03:17 PM Reply With Quote
A bit , yeah - the ECU would need to be built with 6 coil drivers AFAIK
Claire xx
tks
posted on 25/5/08 at 03:30 PM Reply With Quote
or with 3 if you run wasted spark i supose...
Tks
rayward
posted on 25/5/08 at 03:35 PM Reply With Quote
You could just run an EDIS6 , with a coilpack from a 6 cylinder ford, you would just need to sort the HT leads then,
personally i would run an EDIS rather than coil drivers built into the megasquirt
hth
Ray
clairetoo
posted on 25/5/08 at 03:40 PM Reply With Quote
Tks
Um...........with a V6 and coil-on-plug you would have 6 coils , so you would need six coil drivers.....
EDIS is soooooooooo much simpler
Claire xx
DIY Si
posted on 25/5/08 at 03:46 PM Reply With Quote
Righto, I think the EDIS set up looks a bit simpler. Would it not be possible to run a pair of coils from each driver on the ecu? Sorting out some HT leads shouldn't be too much bother either way though.
matt_claydon
Yeah, go with edis, much simpler and less liable to go wrong.
These guys will sort you out with everything you need ready built: http://www.extraefi.co.uk/
clairetoo
posted on 25/5/08 at 03:52 PM Reply With Quote
Plug leads were one of the most expensive things I bought for mine......Mazda caps and Ford coil plugs......cost about £120
[img][/img]
Claire xx
DIY Si
posted on 25/5/08 at 04:09 PM Reply With Quote
How much??!!
Werner Van Loock
posted on 25/5/08 at 07:12 PM Reply With Quote
Could also run the VEMS, it supports COP(coil on plug) up to 8 cylinders or 16 cylinder wasted spark without the need for EDIS. Also 2 channel wideband lambda with builtin driver, so no seperate LC-1 needed. And a bunch of other features.
VEMS UK
official Vems site
http://www.clubstylus.be
posted on 25/5/08 at 09:10 PM Reply With Quote
.....Mazda caps and Ford coil plugs......cost about £120 :
Less than half the price of a set of Vauxhall leads for a V6 Omega!
DIY Si
posted on 25/5/08 at 09:24 PM Reply With Quote
I've clearly led a sheltered life running minis!! I used to get upset at paying more than £20 for a set of 5!
darrens
posted on 26/5/08 at 08:19 AM Reply With Quote
Tks
er!
Wasted spark - 3 coil drivers 1 coil pack
COP - 6 coil drivers 6 coils
Regards
Darren
[Edited on 26/5/08 by darrens]
Schrodinger
posted on 26/5/08 at 08:55 PM Reply With Quote
Can you run wasted spark on this engine?
It will depend on the firing sequence and whether the pistons reach tdc at the same time, I have a feeling that with the Alfa you cannot use wasted spark but I could be wrong. Also with the EDIS6 that presumeably is set for the angle of the Ford V6 and the Alfa MAY be different so timing with that may be an issue. Just my thoughts.
Keith
Aviemore
NS Dev
posted on 3/6/08 at 07:07 PM Reply With Quote
I would also avoid edis, purely from the "why use 2 boxes when 1 will do" point of view.
I have run many engines on aftermarket ecu's, and none have ever used anything other then built in drivers for everything.
