New Topic New Reply
Author: Subject: GTS Adjustable ,Top Wishbones
mad-butcher
posted on 28/5/08 at 09:13 AM Reply With Quote
Has any-one used the above product, and what else is involved
Tony
Mr Whippy
posted on 28/5/08 at 09:15 AM Reply With Quote
lots of phone calls?
vinny1275
posted on 28/5/08 at 09:16 AM Reply With Quote
Whippy, I had a feeling you were going to be the first one to say that!!
mookaloid
I used to have them on my indy.
I can only recommend them - they make camber adjustment really easy and quick, they also mean that you can get the adjustment spot on as opposed to the nearest thread on the ball joint.
Does he still do them?
mark
mookaloid
posted on 28/5/08 at 09:18 AM Reply With Quote
oooh b*tchy
bilbo
posted on 28/5/08 at 09:21 AM Reply With Quote
I have them and they look pretty good.
You can buy them from Rally Design instead of direct from GTS:
Linky
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
Mr Whippy
posted on 28/5/08 at 09:28 AM Reply With Quote
oooh b*tchy
Jubal
posted on 28/5/08 at 11:05 AM Reply With Quote
So, apart from the bones, what else is involved? Do mounts need moving? Other parts required?
mookaloid
posted on 28/5/08 at 12:18 PM Reply With Quote
Straight swap - unbolt the old ones and slacken off the locknut, twist them off the top ball joints.
Connect the new ball joint to the turnbuckle, bolt in the new wishbone on the existing mounts. - Remember you'll need some new bushes and crush tubes as you might struggle to get the old bushes out of the old wishbones.
Finally adjust to give desired camber setting, tighten locknuts and enjoy
Mark
mad-butcher
posted on 28/5/08 at 01:28 PM Reply With Quote
just had this reply from darren price including postage and thieving get tax (boy am I being Polite) works out to about £95. will be ordering later today
Hi Tony,
We don't do the MK style angled jobbies anymore, as i figured out they are the same dimensions as our own Panther wishbones, except for the angled ball joint, which you don't need.
£54 for a pair of top wishbones, and £12.50 for a pair of camber adjusters. You may want to get some new bushes at £2.75 each (8 off required, or pull out your current ones).
Kind regards,
Darren
blakep82
posted on 28/5/08 at 02:00 PM Reply With Quote
as far as i'm concerned, that makes theiving git tax £95...
i don't trust the guy, he's tried doing me over before. never again!
his customer service is er... well, it isn't.
whippy's got the right idea. you might be lucky, but consider yourself warned...
[Edited on 28/5/08 by blakep82]
________________________
ReMan
posted on 28/5/08 at 02:56 PM Reply With Quote
I bought 'em and I like 'em!
They get commented on at shows etc as they look a proper match for the lower wishbones, still better I think than the MK ones even now they are oval tube.
But....
Would I buy them again now, yes, provided I got them Cash on delivery with a target date.
Otherwise, given the feedback on here, I would be "cautious".
HTH
paulbeyer
posted on 28/5/08 at 05:17 PM Reply With Quote
Am I missing the point here? If they are available through Rally design why would you attempt to get them from Dodgy Darren?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
mad-butcher
posted on 28/5/08 at 06:01 PM Reply With Quote
had a look on rally design website only seem to do them for locost and wetfield
nludkin
posted on 28/5/08 at 06:42 PM Reply With Quote
Darren is the supplier of said item to Rally Design. Only difference is that Rally Design seem to be a decent outfit and buy in bulk so as to avoid the inevitable "Darren delays!"
flak monkey
posted on 28/5/08 at 07:03 PM Reply With Quote
You'll get them if you order them from GTS. You might wait longer than from other suppliers, but you will get them.
Ask him for an expected delivery date if you do order them.
They do look the biz as Razman said.
Sera
http://www.motosera.com
Taz Surfleet
posted on 28/5/08 at 10:53 PM Reply With Quote
if you do get them dont forget to grease the turnbuckle well other wise the ball joints jam and you cant get the buggers out without stripping the threads. geuss how I KNOW!!. to be fair Darren replaced them return of post !!
New Topic New Reply
